Originally Posted by
radaja
yep thats good your on water.as for bios's i think there was only one modded one which was done
by hiccookie,it was F4Pi modded for the E8600 for super Pi 1m.
do you have the UD3P or UD3R?
i found F4 to be best with my Q9650 and UD3P.i've only tried F6 and F9 for my UD3R.
but they all behave pretty much the same for the most part,so try the one thats on your board now
and see how it goes.
also i found that my E8500 needed less vcore with my UD3P than it did on my Asus MIIF.so you never
know,maybe you'll get 4500 with less than 1.50v:rolleyes:
good luck getting set up:up:
today i tried for 8.5x530@4505 ddr1272 pl8
it only needed one notch increase in vcore
from 9x500@4500,which i thought was great
for using a lower multiplier and higher fsb.
