Originally Posted by SillySider03
I am starting to think the same way...The DFI is starting to look better and better. But I can't figure out why my brothers Neo2 rocks the house...My 6800OC will do 400Mhz on the core in his machine, which is almost identical, but only 372Mhz in mine no matter what I have tried.
During our last bench session a problem arose with my board. The 2nd RAM slot (2nd from CPU), kind of just up and died. If I put any stick of RAM in slot 2 all the board does is beep when trying to post. I was forced to use slots 3 and 4 for the RAM, with the booster in slot 2, and it seemed to work fine - only my board doesn't OC for crap using slots 3 and 4...
I may try to get slot 2 working again, if not, I may attempt to RMA it. I don't think it was anything I did that killed it because all the settings I run are usually stable (you'll get no suicide screens from me with my PC on the edge). But this is the 2nd Neo2 I have had, and each time this problem follows me...My brother has had 2 Neo2's as well, and both of his work just as they should - unless you are trying to get the RAM speed up...Then you are kinda SOL...But overall, how could 4 of the same boards be so dramatically different in performance? I think MSI is losing their mind...
