I do not know if it includes the modifications of 0096 (and other 00xx)...
according to some, the 1102 bios requires less voltage than the 1005
I thought I see the opposite here...
wow look @ this.. before the pll debate i never touched cpu pll.. always @ stock 1.81.. i could not boot above 215.. i lowered cpu pll to 1.55 and look now i can boot up to bclk 221
If we could get more info regarding QPI PLL.. one can imagine
http://hostthenpost.com/uploads/f1d0...a581caea55.jpg
^ have you tested any 3D with 221 bclk?
no no not tested anything yet :) im just happy to boot with 221 :rofl:
Hi,guys ,
managed to get into the "4.5GHz Linx STable Club " over at XS but what worries me is the
inconsistent performance of this MB .
I got 2 R3E and both maxed up at 222BCLK W/O and 231-232 BCLK w the slowmode .
Tried 3 different CPUS on them , two kits of memory . Moreover, I have observed
the poor 3D performance around 220BCLK at Vantage as reported by Leeghoofd.
All those betas/alfas do not make it better, of course, as its HW /ICH related .
I deem this MB as overrated one for sure .
But well.. what can we expect these days- its just buy and sell, buy and sell as quickly as possible
^I lost performance at 215bclk (as everyone is probably tired of hearing, but idc :shakes:). If someone could figure this issue out I would gladly go back to using the board because it has such a good layout.
seems to b ok here....
[IMG=http://img690.imageshack.us/img690/1184/testmsi.jpg][/IMG]
the problem i am facing is no matter what values i enter high or low the pc wont boot, i cant even get my cpu and board overclock to 4.0Ghz which is something was easy to do with my previous i7 930 and asus p6x58d premium, now since i got the asus R3E and the i7 980x i can even run anything other than the stock speed, my temp for the cput is 27c idel and i am using very good WC system !! :shrug:
the issue exactlly is. after entering the values i get blank screen ( PC doesnt post ) .. even if i dont overclock the cpu and only try the RAM at it is rated freqency it doesnt post, please give me some feed back and help i will appreciate that alot
Some 980X don't like high uncore, high QPI voltages... what settings are you trying to run ? which bios ?
I'm still on 0704, have't had time to test all this stuff out. Thing is I mentioned it too in the review, that the biosses get mixed up by the end user. A bios for a bencher is not the same as one for a daily cruncher... Asus should make it clear which bios serves which purpose (like in the DFI days)
Yeah... I miss DFI/DFI street days...:(
[QUOTE=Leeghoofd;4633519]Some 980X don't like high uncore, high QPI voltages... what settings are you trying to run ? which bios ?
i used both 105 and the latest 1102 ? i tried several settings
20x200 / vcore 1.28v / qpi 130 to 135v / DRAM Bus 1.64v - to 16525v / Ram freq i tried 1450, 1550, 1600 all didnt work ... LLC enabled and disabled didnt work
i also tried different multipliers by BCLK to get the 4.0Ghz it didnt work !!
should i restore the original BIOS ? (9xx):shrug:
i just dont understand i was easily and comfortably moving from stock to 3.8Ghz ti 4.0Ghz to 4.2Ghz with my previous build !!
I don't have another tool and I don't even know of one actually.
It only happens to me when I make changes using Turbo-V and save the changes. What I have found is that Turbo-V gives me wrong DRAM Ref voltages and so when I apply settings, Turbo-V applies the wrong DRAM Ref voltages. The only way I can get the DRAM Ref voltages right is by adjusting them in the bios and not changing any settings using Turbo-V. It doesn't happen to me every time though, its a bit random.
load line calibration, it "stabilizes" your qpi voltage droop
http://valid.canardpc.com/show_oc.php?id=1491825
http://valid.canardpc.com/cache/banner/1491825.png
And uhhh, 1.46 vCore, QPI Slowmode, 1.45 CPU PLL, 1.40 QPI.
http://img255.imageshack.us/img255/3151/226bclk.png
http://valid.canardpc.com/show_oc.php?id=1491825 - 232 Bclk :) Too lazy to take screenshot. Dunno if 3D stable :P All on water, no Ln2 Crazyness haha
I am little curious more than anything else but have there been a couple of reversions of this board yet? If so, what have been the changes?
i know about two revisions 1.04G and 2.0xx, i have rev 1 and its piece of crap a wrote a lot of problems about here, if your getting one choose the newest revision availableor dont get it at all
Thanks.
I have seen 1.04G but haven't seen any 2.0xx
Would anyone know the differences?
So rev 1 and 1.04g?
Hey guys, been running prime95 for 6 hours with these settings, guess i am gonna keep it for my 24/7 ... next weekend gonna try to push the RAM further hopefully without upping the voltage much.
http://img138.imageshack.us/img138/1993/980x415ghz.jpg
