Well, 4.41X is still not 4.5GHz... :)
With which cooling did you run this? HT on or OFF?
I dont know how well the CPU will OC, but with the x24 multi (x25 with the Turbo multi), 201 BCLK will be more then enough. Here are my settings for 201 BCLK, which should at least keep your board stable. But I can't guarantee how well the CPU will OC...
http://i83.photobucket.com/albums/j2...d/IMG_0201.jpg
http://i83.photobucket.com/albums/j2...d/IMG_0202.jpg
http://i83.photobucket.com/albums/j2...d/IMG_0203.jpg
This gets me 4.2GHz HT on, and is Prime95 stable and LinX stable:
http://i83.photobucket.com/albums/j2...nMegahalem.jpg
http://i83.photobucket.com/albums/j2...GHzat1264v.jpg
This should help you get started towards your goal.
What is this driver for?
For Sata
Version 8.9.0.1023
Description Intel(R) Matrix Storage Manager Driver V8.9.0.1023 for Windows 32/64bit XP & Windows 32/64bit Vista & 32/64bit Windows 7.(WHQL) Intel(R) AHCI/RAID Driver Disk for Windows 32/64bit XP & Windows 32/64bit Vista & 32/64bit Windows 7.
File Size 23.61 (MBytes)
http://www.asus.com/product.aspx?P_I...Mih&templete=2
Hello guys! I'm not new to this forum but I haven't really been on for awhile. I am wanting to become more in tune with my Rampage II Extreme and GENE on X58. I will do my best to read through here to find some insight tips on area of voltages and frequancies but if anybody is willing to PM me with shared notes on a DO i7 920 on this mobo that would be cool. I got a stable daily 3.8GHz at 200x19 w/ DDR1600. I did a few bench test at 4GHz with 20x200 DDR 1600 but got a few BSOD's so I believe I need to learn more of the safe voltages to rais and in what order for safe daily as well as cool running. I will post BIOS template as soon as I get my notes in order.
Thankx in advance!
Hey Nuckin Futs congrats on your new R2X . Throw up your idle and 100% load temps to give us an idea what your working with .
Things have now changed a bit on my main PC. I got the Corsair H50 with dual fans, and installed it today. Temps seemed to have went down from what they where before. On the stock fan i was doing 135F only on idle alone. Now i am doing about 111F on idle. I ran those test from what you can see in the pic's. I am for now running at stock speeds, along with memory (Corsair XMS3 6 GB 1600mhz). Let me know what settings I can try and where I can take this beast, lol. Thanks again.
http://img9.imageshack.us/img9/5940/benchmarkc.png
http://img41.imageshack.us/img41/8966/mainpc.jpg
Well good move on your cooling upgrade . Your now around 43c at idel with stock settings . Lets try for 4.0Ghz first . Go with a x20 ratio & 200 BCLK & core voltage lets use 1.40v . Run LinX 20 times using all memory . If you fail LinX bump up the core voltage to 1.4375v and run LinX again . Watch your temps while LinX is running and report back with results . If temps look good we will push for more and then when you reach your max safely and stable we will fine tune that core voltage .
I started to run LinX and I was not comfortable running it when i saw the high Temps in CoreTemp hit turn orange and hit187F after a few seconds. I ran it under both Voltages with the same result. Right now i am running at 4GHZ with Core Voltage at 1.4375. Should i lower it to 3.8? i am not sure if this will hold when i start to play COD4 or GTAIV, thanks.
That would about 80c it was hitting on you for core temp running LinX . That is very except-able temps for LinX stability testing for i7 9_ _ series processors . Take a look a couple pages back here with my post on LinX runs and look at my temps . Can you post your temps in Celsius please ? Run LinX for 20 times with all memory with the 4.0Ghz settings and that will tell us if your 100% stable there . Use the lower voltage first I gave you .
I tired to run it with 1.4V and all memory and it blue screen on me after about 20 seconds or so, with temp readings around 90C. I bumped it up to 1.4375V but saw the same and i stopped it about 30 seconds in.
@My dog. I have all those settings at Auto.
Ok Try this: Dsable ALL settings exept HT under CPU Conf.
AI overclock: Manual
CPU ratio: 21
CPU turbo: Disabled
BCLK: 200
PCIE Freq: 100
Dram Freq: 1333 or 1600
UCLK Freq: (2x Dram freq) 2667 or 3200
QPI Link: Auto
Dram timing: What it says on your mem (ex. 9-9-9-24)
Load-line Clib: Disabled
CPU Diff. Ampl.: Auto
CPU Voltage: Start with 1,3
CPU PLL: 1,81592
QPI/DRAM: 1,3 for(1333) or 1,4 for (1600)
IOH:1,17966
IOH PCIE:1,511
IHC: 1,17966
PCI IHC: 1,511
DRAM Bus V: 1,65681
CPU Spread Spectrum: Disabled
Leave the rest as it is
http://img63.imageshack.us/img63/2638/stable.png
90c is high , I don't like that at all ! Address your cooling because that will hold you back . I suggest you do not try for more then 4.0Ghz with the temps you have now . 4.0Ghz is a respectable frequency and will give you fine over all performance . I would like to see you lower your temps and until then lets try to get 3.6Ghz 100% stable for you . If that is okay with you let me know . I could right you a book on over clocking but slow and steady wins the race . Over clocking safely is the #1 priority . A bit of information zoo81 is you only have with a i7 920 X20 cpu multi ratio with Turbo disabled . Leave Turbo disabled and use X20 cpu multi ratio hard set in your bios . When Turbo is enabled that x21 cpu multi ratio is only good for one core and is useless for overclocking in my opinion . If you would like to zoo81 you can run p95 to test for stability . It is less stressful then LinX and you will see lower temps when its running but I believe it will declare your over clock stable for you , not as stable as a LinX stable rig .
Can anyone help me with this issue:
I have a rig based on the rampage extreme II. core i7 cup 920@3.8Ghz, 6GB RAM, 2 750GB HDDS in a Raid0 configuration and 3xGTX285 GPUs in an SLI configuration.
Windows 7 Home Premium 64bit is installed.
I would like to use standby mode. But unfortunately the rig does not wake up when I restart from standby. It won't boot but it powers up (no boot screen though - the display remains black [no signal]).
Does anyone have an idea how to solve this (hibernate works though)?
