Come on post the clocking ;)
Anyone seen this stepping: ccbbe 0615mpmw ? Is it a :banana::banana::banana::banana:ty stepping or is it the rest of my hardware thats stopping me?
My 185 is a CCBBE 0613MPMW and it does 3Ghz on stock voltages. Granted it starts at 2.6Ghz stock, but it seems ours were just maufactured at different times.Quote:
Originally Posted by LIKMARK
I got that stepping too, and it suxx :stick:Quote:
2,6 ghZ with 1,4 volts
Hi everyone. I wanna brag about my opty too after seeing all of yours.
Opty 175 3081 MHZ 1.312V The infamous CCBBE 0617 EPWM
DFI Expert
7900GT's in SLI
Ambients 71-72F
http://i125.photobucket.com/albums/p...rla/MyOpty.jpg
My cooling
http://i125.photobucket.com/albums/p...a/IMG_0397.jpg
mmmmmm, i think i hit 3.37 on 1.52V . But i bought a QX and was messing with it for a while. Sold the QX and went back to this baby. I honestly i like to keep things chilly. BTW im half debating on dropping my TEC that i pulled off the QX onto this rig. But, time is not letting me get around to it. :T
:toast: Wow, sweet OC for a 175! :clap:
whats really funny about my CPU is she doesnt like 1.45V She either likes it lower then 1.4 or higher then 1.5
I have no idea why... but as you can see, any chip that oc's to 3.0ghz on stock voltage is thumbs up for me.
But yeah... anyone else with a CCBBE 0617 EPWM should test this theroy.
I fail at 2.9ghz on 1.4V incase your wondering. Its REALLY REALLY wierd. And on stock voltage i'll prime for hours and hours at that clock.
Well got a LCB9E 0652WPMW.
Will install tonight and see how it goes ;)
My Opty 185 has so far OC'd as follows:
Stock 2600 @ 1.3v
OC to 2733 @ 1.3v
OC to 2880 but needs 1.35v to startup and 1.42v (5%) to pass Prime testing.
Full load (two FAH clients running) temps are about 50c.
Well currently Orthosing at 2.6GHz (260 x10) at stock voltage, temps with the XP90C are 50/57 C full load. I think I need to get that Tuniq Tower ;)
But so far so good.
2.7Ghz passed Orthos at stock volts for 14 hours, but them locked up when I opened CBID and Coretemp at the same time :confused:
Any idea chaps?
what priority are you running orthos under? 1 or 10?
@Draxx - CoreTemp is still beta 0.94 and there are reports of lockups and random reboots in their forum, I had a few as well mainly if I left it running in Systray but also when using CBid & CPUz.
I normally Orthos using Blend test @ Priority 5.
I as well get random reboots while using core temp 0.94 and cpuz 1.39
312x9 = 2808Mhz stock volts
prime95 25.1 dual core edition 53 hours blend stable (I was away for the weekend)
35/36 load temps
water cooling cather's G4
Well I'm happy its stable at 2.7Ghz 1.33v. Did about 5 hours Orthos priority 10.
A third 165 added to my collection
LCB9E 0704XPMW
Will see what she does starting this weekend
Smiffy
CCBBE0610 hit 3050Mhz on 1.58v.
Warmin it up a bit
2100Mhz on 1.250v
Smiffy
Opteron 165 CCBWE 0633 XPMW is not very good, 2600mhz @ 1.4v max
boxed cooler.
Unfortunately the temp sensors are broken so this one is going rma. (:
