You do realise that benchmark is highly unfair?
SB system has 16Gb of RAM, BD only 4Gb
SB system has 120Gb SSD, BD only has 500Gb HDD...... Anomolies like this usually make me question the authors intent......
Hyperthreading seems to work well on BF3 and that indicates that there are a lot of cache misses. When the CPU-core waits on memory it kan jump to another thread. Cache misses also indicates that much memory and/or complicated memory patterns are used. Higher frequency is good but avoiding going to ram for data is also important.
If BF3 would have dedicated threads for different tasks, like one render thread, one AI thread etc then hyperthreading is not good.
When work are sliced in smaller jobs it is also important that threads are able to synchronize fast. Don't know if there are improvements there on bulldozer.
F.E.A.R vs BF3 beta
http://gamegpu.ru/Action-/-FPS-/-TPS...-test-GPU.html
http://gamegpu.ru/plugins/content/ju...5wbmd8QlJ8MzA=
http://gamegpu.ru/plugins/content/ju...BuZ3xCUnwzMA==
Yer looks like it - I forgot to mention I used Cat 11.x (older ones) for the first bit of testing and the newer 11.10 BETA drivers for the AA testing - Them 11.10 drivers are well crap - First I got a black screen (could just see team members lol!) - Then I started to get loads of glitching. At least with the older drivers I was completely stable!!
Probably not a fair test - but from what I'm reading it helps to have 1.5Gb+ cards when running this game. Hey ho - Guess I'm still happy I can run it maxed out (without AA of course lol)
If anyone out therre is testing - don't forget to restart the game as video setting changes DEFINATELY don't take place until then.
Yes I have to agree after running some fast tests on my system, it seems that I have been wrong and BF3 does like more cores over more frequency. I made too fast conclusion on max cpu usage pattern.
I tested with different cpu affinity & different cpu clocks. Most noticeable difference was that with only two cores used @ 3,6GHz was noticeable lag and much of it, but with four cores @ 1,8GHz it ran very smooth.
It was not in anyway scientific, I only used fraps, task manager et AOD. No charts were made. Btw, it run 38+ fps with 6 cores @ 1,8GHz.
GPU used is HD6870 @ stock. Settings: All high, no-aa, aniso 16x, HBAO, 1680*1050, cat 11.10pre.
Interesting! BF3 almost acts like serverapplications. Frequency isn't allways that important, more cores and fast memory access is sometimes better.
I know that many gamers buys i5-2500K because they want to be prepared for future games. But if this is the future than that CPU will not be as future safe. Less L3 cache (6MB) and only 12 way set associative. Games using much memory and/or complicated memory patterns and i5-2500K cache is trashed in no time.
Quote Originally Posted by gosh View Post
Question??????? the I5-2500k is a 4 core 4 thread processor???? If so and gamers bought it to play games, then they are not going to be happy as they don't have the HT to help them out.
Speaking nonsense here. 2500K L3 cache is 2-3X faster than Phenom and Thuban.
Not to put also the IMC much, much faster.
So if it is 6 or 8MB it doesn't coun't.
How that BD with a total of 16MB cache doesn't overall beat 2600K?
If it would be so, than the price vouldn't be 245$.
The most stupid thing i ever heard...Until no we even don't have games to use more than 4 cores or threads.Quote:
Gamers should take care to buy a strong vga.
Will see about that if BF3 knows more.
And tests at 640*480 is also the bigest nonsense i ever heard.
thanks for the reality check. if the 2600k blew past bulldozer in math benchmarks by that much, I don't see what place bulldozer would have in servers.
also, even in the misleading benchmarks where bulldozer loses everything, the one thing it wins is floating point math. if bulldozer wins at floating point by such a large margin, that alone may make up for its IPC weaknesses WHEN PLAYING GAMES!
Look at this: http://semiaccurate.com/forums/showp...postcount=2208
If this is true, I was _very_ close with my math skillz =)
radaja, did you post the below over here yet? I seriously laughed at this.
"well i can tell you it should be bright and sunny, based on what i have been told
from my contacts.....
my brother works at AMD and he said all is superb with BD
my sister works for Global foundries and she said 32nm is 100% perfect
my grandpa works for the Guiness Book of world records and he said BD is the fastest CPU in the world.
my uncle works for Cray and he said Interlagos is the most powerful CPU ever made.
my other sister works for intel and she said everyone is very scared right now at intel and are struggling
to come up with a solution to BD
my mom works for Cyberpower PC's and they are planning on dropping all intel based machines in favor
of AMD's BD for the next 5 years
but this is all just a bunch of BS on my part,nothing i just said is true"
AM3+ Socket?
No dates when these slides were made?
I not only notice the integer performance increase(like Phenom to Llano) but more important is the FMA3 support which is only support on Haswell with Intel plan!:eek:
How should there be PCI-E 3.0 and USB 3.0, when they are still using the AM3+ plattform with the 990FX Chipset?
Technically it might be possible to use the A75 FCH instead of the old SB850/950 to gain USB 3.0 but it doesn't solve the problem of PCI-E 2.0 in the aging Northbridge.
If those slides are legit, they can't be that old, since 2nd Gen Bulldozer was supposed to use socket FM2 and the change to stick to AM3+ was only recently.
