I am using air.... :D
ur temps are fine candymancan.
they are exactly the same on my watercooled chip 334x9@1.55v, although i also have two x1800´s in the same loop. AtiTool reads 40°C on the vidcards during an Orthos run.
Running 246x11 @ 1.53v on my Opty I get 32/46 on CoreTemp. ASUS Probe II shows 40°C, ambient 21°C - see sig ...Quote:
Originally Posted by CandymanCan
I have my rig stable at 2880@stock volts. :toast:
http://i118.photobucket.com/albums/o...6/opty2880.jpg
I was taking a screen capture and I noticed that cpu-z was showing my 165 as a toledo. Is this A bug with cpu-z? I am not an expert overclocker I think that I need to start tweaking my ram and see if I can get some better timings. Anyhelp would be great.
1,36v is for 1,4v in bios when set manually, real stock voltage imho is when it's set to Auto and it's about 1,29-32v in cpu-z ^^
edit: I havn't read your sig, you've asus. I'm talking about DFI nf4 D ...
Well I guess add LCB9E to the list of 'don't get if you want to hit 2.8'. The highest I can manage is 2.736 @ 1.425V in bios. It doesn't like anymore voltage even though it runs cool as can be. I can't even load into windows above 2.75 ghz. :mad: Oh well, still a great processor so I'll be keeping her.
http://img254.imageshack.us/img254/7...os10kv1.th.jpg
I was just wondering, if you guys having trouble overclocking have C&Q shut off?
don't include all LCB9E because yours tops there.Here's mine at 2.8 with 1.4Quote:
Originally Posted by Chain
http://img163.imageshack.us/img163/6479/2800lz9.th.jpg
and for 24/7 at 2.9 1.525 with watercooling of course..
http://img341.imageshack.us/img341/5...louspg1.th.jpg
The LCBQE is the new trend...ive got 0702WPMW....nothing special (Opty180,sold the 175 CCBWE..)...right now iam at 250x11.5=2875MHz with 1.425 Vcore..keep trying..keep burnin in ..Quote:
Originally Posted by DevilCry
[OFFTOPIC]Ε παντερμη Κρητη....εβιβα χωριανακι..[/OFFTOPIC]
why 11.5?..are you there with aircooling?and congrats for your new cpu
[OFFTOPIC] ..εβίβα! [/OFFTOPIC]
Originally Posted by nick2crete
I knew it..finally 2007 939 Opteron chips are showing up. Hopefully we'll be seeing some amazing proc's with darn good refined mem controllers and processes.
Or...they will use all the crappy chips for the 939 since there is obviously a lot less emphasis on it(lowest priority for AMD).
hi there, where on earth did you get those 2007 edition opterons, just curious.. ? :woot:Quote:
@DevilCry thanks man!
I prefer this multiplier becouse my mobo then change the divider to 180:200 so my ram run now a little over the 200 stock..otherwise i should go to 3GHz to have the ram run at stock speed..(Asus dont have this divider in bios settings..)
@xforce
I bought this in Europe-Greece and i know also from other forum that in Germany they offer right now the same steppings....
Simply,no IHS :DQuote:
A friend of mine just received a OPTY 170, his stepping is LCB9E 0651MPMW
I haven't seen this stepping before, anyone else got some input on this stepping ?
From www.komplett.com?Quote:
Originally Posted by furyfax
Not exactly, but the webshop he used has the same parts deliverer as komplett i believe.. So should be the same...Quote:
Any idea how its clocks? As I'm about to buy a 170 from Komplett ;)
Will know more how it clocks within the next 12 hours...
:toast:Quote:
From what I've seen around the LCB9E stepping has been sort of inconsistent. I've heard them as high as 2900 and as low as 2500's, with varying voltages but nothing to brag about.
Hope you get one of the better ones.
only one and it apperantly doesn't overclock, but don't take my word for it tell your friend to give it some juice and find out for himself.Quote:
