Well Prime eg gives you the feature to test CPU alone... when you want eg to determine "stable" Vcore, thing I don't like about prime is that it doesn't stop if the clock isn't "stable". this is one of the reasons I use OCCT for CPU, then RAM and then Mix test. Afterwards a Linpack 10 run test (maximum memory) and then some benchmarks... then it's off to folding and daily abuse... I like linpack as it can be used as a brief test but I see some run 100 plus runs, which is kindda hard on ya hardware as in daily usage you don't push it that hard... and AgentGod also states it is best used under 64bit OS... which not everyone has...
you can have your opinion; freedom of speech also is valid here, but try to bring it a bit softer lol... also bear in mind not all clockers here are english (like me) so sometimes we take it the wrong way...
