Where is the problem ? :confused:
http://img107.imageshack.us/img107/4...07300fe.th.jpg
http://img151.imageshack.us/img151/7...07319ui.th.jpg
that could only be a bad luck, redownload the zip file and have another try.Quote:
Originally Posted by Donni
the flash utility works no problem here, i even flash when overclocking to 3G
you flash with the Winflash utility? :rolleyes:Quote:
Originally Posted by joe_cool
bootable USB stick all the way here :)
Just downloaded the file and used winflash. No problems at all ;)
What's the cpu VTT for? What does it do?
TBH i have nfi whats that, and it seems not to help oc anyway...Quote:
Originally Posted by WeedJunk
Is this bios better than 103c?
Can it handle neg temps? is it reversible to 103c?
Thx
I just installed a Merom 7400 on this board and I'm using a Zalman 9500 for cooling. I protected the core by laying Scotch tape on 2 sides of the chip.
What is a good temperature to expect when in BIOS?
I applied too much tape at first and the heatsink wasn't making good contact b/c I had almost 80C temp in BIOS. I removed a few layers and the temp dropped to 38C. I don't know how much more tape I should remove to get the optimal temp while maintaining the best protection using the tape. If I remove more layers, I may get lower temps but run the risk of cracking the core.
Please post what temps you register in BIOS and what type of cooling.
Thanks.
Which heatsink are you using? You don't want to use so many layers that you're getting in the way of contact. Use a razor to make sure that the tape is at the exact same level (or a hair lower) than the core. I was seeing low 20's at stock speeds in BIOS on a Tuniq Tower.
Couple of questions,
1. Are you guys seeing below ambient temps in bios, I'm seeing 13C in bios with air cooling and 20-21C ambient
2. To disable raid, disable ide controller, but if you have an Nvidia Graphics, black screen at windows? Correct? So enable raid?
3. Are you guys having warm boot issues? Cold boot is fine.
4. How do I set Tras? bios issue? or ram issue? I set it to 10 in bios, and cpu-z shows 14
If the heatsink is not making good contact with the core, you may experience boot problems. Don't use the HSF that comes with the board. It's junk. Use a real heatsink. Pads are good if you're worried about chipping the core.
You can set Tras once in Windows using a program like MemSet.
Hassan, to answer your questions
1. Yes. My watercooled T2600 reports 3C while ambient temp is 14C with core temp beta and bios
4. Same issue here, memset should fix the prob
I have some questions too
Anyone hear a high pitch electrial buzz sound when moving the mouse or moving files?
Is there a temp sensor on PWM? mines will go above 60C idle sinked (handheld temp sensor)
I'm using a Big Typhoon, and I'm using pads, when I doesn't warm boot, I power it off, power it on go in bios and temps are 13-16C. Thats what I was afraid of, lol seeing subzero with watercooling!!
So, if speedfan says 35-38 load, then really I should add 15-20 to that number, coretemp shows 45 and 38
Originally Posted by Hassan
just for fun i ll try to acheive subzero temp and take pic in bios
subzero pure liquid distilled water!!
You'll never see subzero with bios 103C (thank god :p: ). At -104C, my bios still reads 1C :DQuote:
Get ready to have your rig lock up as soon as you hit under 0.....I've tried to see what happens when I adjust the pot on the Tcore mod while aircooling and I can get into negative numbers only to have the system lock up immediately @ temps below 0.....(with the older bios revs.)Quote:
Originally Posted by PkG.1337
1.03C has its own weirdities...it seems that once you get cold enough, you're all set. Apparantly LN2 and the sort of temps you're getting on the autocascade are all good...DI seems to fall into the worst range where it starts spitting out "224C/1f" and won't let you get into windows. :-/
Were you in BIOS when doing this, or in Windows? I've run 1.03B without the TCore mod well into the subzeros.Quote:
Originally Posted by s7e9h3n
BIOS...With 1.03B, I can't get into bios AT ALL when subzero but can boot into windows fineQuote:
Originally Posted by Gautam
Thanks for the info. It seems that I still have too many layers of tape on the sides if my temps are high 30's and most of you seem to have temps in the high teens/low 20's.
Originally Posted by sierra_bound
I have now the 1.04 running, can´t find any changes...
I did my DICE-action with the 1.03c. DICE gave me 1M 25 MHz higher FSB (from 250 to 275)...:D
same here, no improment with the 1.04
it probably got out just for the support of VT in the T2700
Hi All,
New to the forums really, but my new kit hopefully earns me the right to post here :)
My T2600 and 975X a-YDG seem fairly typical based on what i have read in this and the other threads.
I can get to 233FSB and no further regardless of Vcore (vcore mod thanks) or any other settings. Using 1.03c bios and agree that is seems to give a good all round stability.
So i get 233 X 13 with some cheap Gskill HZ 6400 running 3:5 4,4,4,12
Here is what i have tried to get past 233
- Up to 1.65 vcore (but it sits as happy at 1.5 as it does at 1.65)
- Max Vdimm 2.15 (not done vdimm mod)
- Relaxing memory to 533 and stock
- Clocking in windows and Bios
- Talking to it nicely
- Giving it a kick
- Only tried Air so far - I dont think i will get further with the VC LS tbh
A small point of note is that i was stuck at 231 until i put a fan over the South Bridge area.... maybe its the southbridge that gets stuck?
Any comments or suggestions would be very welcome.
Welcome @ XS! :toast:
How hot is the SB?
Normally it´s a CPU-issue, when you stuck...
Try to get deeper temps at CPU, maybe outside with colder air od put it under water.
I got my T2600ES 1M to 250 MHz x 13 @ Air and 275 MHz x 13 under DICE...;)
