Originally posted by uwackme
I may take you up on that Hell, I'll let you know.
I dont actually have any 2x 256M BH5, my goal in bothering at all was to get higher than my 1Gig of CH5 was able to with the full gig in. So I have no way of knowing if this is BH5 period or a doublesided stick issue. I tend to think it is a DOUBLESIDED bios settings issue, since the sticks DONT SCALE at all. Going to 11,3,3,2.5 does NOT yield any change in results.
I would think, if the sticks were marginal, that looser timings would yeild a little change for the better in FSB, but it has 0 effect.
I also only have 1 stick of CH5 512M, Ill borrow a couple Corsairs CH5 512M sticks tommorrow for testing the doublesided issue a little, though 2x256+512 is supposed to be the same as 2x 512.
On a side note: I have a friends NF7 in for testing. It too dont like my BH5, but also, with absolutely IDENTICAL mods/heatsinks/ram and CPU, it does not get anywhere near the max FSB that my two NF7's get. Where I can memtst 11,2,2,2 @ 250, he cant memtest at 220 11,2,2,2....needs 11,3,3,2.5 to error=0.
Guess he just has a lemon of a SPP chip. When I say mods, I mean every mosfet/sb sinked, Swifty on NB, alpha on CPU, same exact vmod's same voltages, etc. Pegged at 3.3Vdimm his just dont get there.
On a bright side, his burnt in CH5 2x 256 does the same 11,2,2,2 @ 250Mhz in my two NF7's.
Hell, you think it's a case of some SPPs liking BH5 and some not? As well as there must be memory controller settings being used in the bios code that are just not compatible with this stuff. BH5 is a bit exotic for the mainstream customers of the 1 MILLION per MONTH they make of these boards.
I will be here if you decide to either send me your ram for testing or me send you mine.
