Copper does more performance but has less corrosion resistance? Nikel does less performance but has more corrosion resistance?
I think this block is good http://www.aquatuning.de/product_inf...70-Nickel.html
I have Feser One coolant btw :up:
My EK block seems to perform fairly well.
Just did a test using the Heaven demo under DX11 and my GPU temps never exceed 32C. VDDC temps ranged from 40-43C.
the nickel plating on the copper is so thin it wont hurt performance. what the cover is made of doesnt matter, so all 4 versions will perform the same. IF you have aluminum in your loop, i'd strongly recommend either nickel one, but if you dont the copper is fine too. from your sig i can conclude you have only copper, so just pick the one that looks best.
eta on swiftech full cover block for 5850?
umm, according to this: http://www.engineersedge.com/galvanic_capatability.htm, nickel would corrode with aluminum even worse than copper. Mixed metals do not work unless they're close enough.
Gabe,
I've got an MCW60-4870 sitting here I never got around to using.
Will it fit on my nice new Sapphire 5850?
I'm thinking that the spacing to the VRM's might be a little different, but you have the data to correct me on that.
If so, any chance of an upgraded heat pipe as an accessory?
cheers, drayzen
Just watercooled both my 5870 cards using the Ek waterblock.
prob is my gpu temps under load hit 55c and my vddc temps go up and over 80c. im using thermochill pa 120.3 rad and a stong pump. but im using standoffs. will it be better not using standoffs. can some 1 guide me installintg blocks without standoffs. thx in responce.
All temps are high.
What is the difference between idle and load?
What is your water temp?
Eddy_EK
I`ve just ordered your block
Have never used GPU blocks in my loop earlier. I will use only 2 fittings (no CF). Is there something like plugs in packaging arrangement to close other 2 threads?
Tackleberry
Thank you :up:
Very happy with my koolance AR587 (which is also compatible now with 5850 which is what I have) .. everything under 50C (gpu, mem, VDDC) .. and looks great to boot :D
and now it has arrived :D
http://www.abload.de/img/053_bildgrendernhvuq.jpg
http://www.abload.de/thumb/h2obwoe.jpg
Don´t ever do what I did: Far too many monitoring tools :rolleyes: The gpu temporary switches over to 1,65 V ... Everest OR GPU-Z will do it.
scamps
congrats man. This block is ultimate :up:
That is a sharp looking block there scamps.
Looks excellent, nice temps also! Congrats! :up:
Thank you! What is more it was unbelievable easy to mount this sweet little silver baby ... it fits absolutely perfect :up:
Some Details (in german language only): http://www.hardwareluxx.de/community...d.php?t=655756
