Heey Hicookie the BIOS F4PI also worked with the same configuration on an E8500?;)
Has anyone tried a Q6600 in this board? See only Wolfdale/Yorkfield shots. :( :)
Hi friends. :cool:
I have a problem with the FSB of my Mother Board :confused:
this is my setup at the moment and I can not climb over the FSB.
any suggestions? :eek:Quote:
GIGABYTE GA-EP45-UD3P
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .................: [Auto]
CPU Clock Ratio .........................: 9
Fine CPU Clock Ratio.....................: [+0.0]
CPU Frequency ...........................: 4.68GHz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled] [Disabled]
CPU Host Frequency (Mhz) ............: 520Mhz
PCI Express Frequency (Mhz) .........: [Auto]
C.I.A. 2.............................: [Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 700mv
PCI Express Clock Drive...................: 700mv
CPU Clock Skew (ps).......................: 0ps
MCH Clock Skew (ps).......................: 0ps
DRAM Performance Control
Performance Enhance....................: [Turbo]
Extreme Memory Profile (X.M.P.)........: [Disabled]
(G)MCH Frequency Latch.................: [Auto]
System Memory Multiplier ..............: 2.00B
Memory Frequency (Mhz) ................: 1040
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time...............................: 5
tRCD ..........................................: 5
tRP'...........................................: 5
tRAS...........................................: 15
Advanced Timing Control [Press Enter]
tRRD...........................................: 5
tWTR...........................................: 5
tWR............................................: 8
tRFC...........................................: 52
tRTP...........................................: 5
Command Rate (CMD) ............................: 2
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value......................: [Auto]
tRD Phase0 Adjustmen...................: [Auto]
tRD Phase1 Adjustment...................: [Auto]
tRD Phase2 Adjustment .................: [Auto]
tRD Phase3 Adjustment..................: [Auto]
Trd2rd(Different Rank)..................: [Auto]
Twr2wr(Different Rank)..................: [Auto]
Twr2rd(Different Rank)..................: [Auto]
Trd2wr(Same/Diff Rank)..................: [Auto]
Dimm1 Clock Skew Control................: [Auto]
Dimm2 Clock Skew Control................: [Auto]
DDR Write Training......................: [Disabled}
Channel A Driving Settings [Press Enter]
Driving Strength Profile:..............: [AUTO]
Data Driving Pull-Up Level.............: [Auto]
Cmd Driving Pull-Up Level..............: [Auto]
Ctrl Driving Pull-Up Level.............: [Auto]
Clk Driving Pull-Up Level..............: [Auto]
Data Driving Pull-Down Level...........: [Auto]
Cmd Driving Pull-Down Level............: [Auto]
Ctrl Driving Pull-Down Level...........: [Auto]
Clk Driving Pull-Down Level............: [Auto]
Channel B
Channel B Timings Settings [Press Enter]
Dimm1 Clock Skew Control................: [Auto] ps
Dimm2 Clock Skew Control................: [Auto] ps
Channel B Driving Settings [Press Enter]
Motherboard Voltage Control
Voltage Type. ... ... Normal
CPU
Load-Line Calibration....................: [Enabled]
CPU Vcore . .........1.22500V*.........: 1.4500
CPU Termination ...... 1.200V*...........: [Auto]
CPU PLL .........1.500V*...........:[Auto]
CPU Reference..........0.760V............: [Auto]
MCH/ICH
MCH Core ..........1.100V............: 1.400
MCH Reference.. ... . .0.760V............: [Auto]
MCH/DRAM Reference.....0.900V............: [Auto]
ICH I/O .... ......1.550V............: [Auto]
ICH Core...............1.100V............: [Auto]
DRAM
DRAM Voltage ........1.800V............: 2.32
DRAM Termination ... ..0.900V............: [Auto]
Channel A Address Vref 0.900V............: [Auto]
Channel B Address Vref 0.900V............: [Auto]
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect.................: [Disabled]
CPU Enhanced Halt (C1E)...................: [Disabled]
C2/C2E State Support......................: [Disabled]
x C4/C4E State Support....................: [Disabled]
CPU Thermal Monitor 2(TM2) ...............: [Disabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology.................: [Disabled]
Note: * refers to 45nm CPU
its simple to make you fly
65nm of intel processor, try CPU termination 1.4v
also, you need CPU PLL for 65nm processor, try 1.6~1.8v
45nm, just pull higher CPU termination, 1.32v(540FSB)~1.6v(600FSB & beyond)
i see you change memory ratio to match your memory, thats smart way:)
It took me awhile to get things set up, because at first, I experienced random reboots and instability.
I went back, disconnected all power/data cables and all cards, and removed/reseated the RAM. I also clipped the ends of two of my PSU's SATA connectors and replaced them with right-angle ones, and went with right-angle SATA data cables to remove kinks.
The system is now up and very stable, with a RAID 1 mirror for my boot drive, and a third 1TB drive for media storage, running the F5 BIOS. Since I had a Tuniq Tower, I also had to dremel the K8 "nipples" off the sides of the mounting clip so that it would fit well. I have only just reloaded the OS, and will be restoring data in the next 48 hours. I'm running at stock settings for now until I have everything set up just the way I want it; at that point, I'll consider doing a minor overclock to go up to 1333 FSB. Stock performance of the board is quite good, though.
Sounds good. I still do not know whether to switch over. Probably I'll buy a new psu 1st, as during 3dmark06/Vantage cpu tests my rig just switches off. :) :(
i cant get 4.0 stable in orthos >_>
after 2 minutes error :(
(Easy tune6 are the same settings i have put in the bios)
http://i430.photobucket.com/albums/q...g?t=1234420385
i have enable line-calibration on bios
PC:
E8400 C0
Gigabyte EP45-UD3P Rev1.0 Bios F7 (official from gigabyte)
G.skill 2x2GB 8500C5
TT Toughpower 850w
Win XP SP3 with all the update from microsoft
Dunno if this will be of use but here are my settings for 530mhz 5:6 Stable - 500 Linpack Loops passed, 24 hours Prime95, 12 hours looping 3d06.
Note - this memory has problems running 1:1 ratio, it only likes the upclock dividers. Confirmed on biostar and gigabyte boards.
M/B: EP45-UD3R
CPU: E8500 E0
Memory: Kingston HyperX PC9200 2 x 1gb (Elpida)
GIGABYTE GA-EP45-UD3R
Robust Graphics Booster .................: [TURBO]
CPU Clock Ratio .........................: 8.5x
Clock Chip Control
CPU Host Frequency (Mhz) ............: 530Mhz
PCI Express Frequency (Mhz) .........: [103]
CPU Clock Skew (ps).......................: 200ps
System Memory Multiplier ..............: 2.40B
Memory Frequency (Mhz) ................: 1272
tRP'...........................................: 4
tRRD...........................................: 2
tWTR...........................................: 2
tWR............................................: 4
tRFC...........................................: 38
tRTP...........................................: 2
Channel A
Static tRead Value......................: [9]
tRD Phase0 Adjustmen...................: [1-Advanced]
tRD Phase1 Adjustment...................: [1-Advanced]
tRD Phase2 Adjustment .................: [1-Advanced]
tRD Phase3 Adjustment..................: [1-Advanced]
Trd2rd(Different Rank)..................: [5]
Twr2wr(Different Rank)..................: [4]
Twr2rd(Different Rank)..................: [4]
Trd2wr(Same/Diff Rank)..................: [7]
DDR Write Training......................: [Enabled]
Driving Strength Profile:..............: [OC-1333]
Channel B
CPU Load-Line Calibration....................: [DISABLED]
CPU Termination ...... 1.200V*...........: [1.220]
CPU PLL .........1.500V*...........:[1.500]
CPU Reference..........0.760V............: [0.757]
MCH/ICH
MCH Core ..........1.100V............: 1.300
MCH Reference.. ... . .0.760V............: [0.754]
MCH/DRAM Reference.....0.900V............: [1.070]
ICH I/O .... ......1.500V............: [1.500]
ICH Core...............1.100V............: [1.100]
DRAM
DRAM Voltage ........1.800V............: [2.14]
DRAM Termination ... ..0.900V............: [1.070]
Channel A Address Vref 0.900V............: [1.070]
Channel B Address Vref 0.900V............: [1.070]
Advanced Settings
No-Execute Memory Protect.................: [Enabled]
Dymblos,i think maybe your mch ref voltage is too low(0.66),bring it up a few notches so it reads in ET6 as 0.70 to 0.76.start with 0.70 then try 0.74 and so on,till it works.also set your vMCH(NB voltage) to 1.30.good luck
here my setup with EP45-UD3P
fsb 675mhz
CPU on Dry Ice - 39:(
NB Stock
http://valid.canardpc.com/show_oc.php?id=507320
good board, i test with air cooled pushed manage 620MHz bench :up:
i do a little test with minum voltage for 580MHz
CPU vcore: 1.200v
CPU PLL: 1.65v
CPU VTT: 1.20v
CPU / REF: 0.76v
RAM:2.0v
MCH: 1.30v
Super Pi 32M pending...
http://img248.imageshack.us/img248/3...032m001re7.png
Finish
http://img7.imageshack.us/img7/9972/...032m002rj6.png
continue doing priming test with FSB 580MHz
i add some voltages to make sure it could run 24hrs
here the voltage i add
Super PI 32M
CPU vcore: 1.200v
CPU PLL: 1.65v
CPU VTT: 1.20v
CPU / REF: 0.76v
RAM:2.0v
MCH: 1.30v
Burn-IN
CPU vcore: 1.200v
CPU PLL: 1.67v
CPU VTT: 1.22v
CPU / REF: 0.76v
RAM:2.0v
MCH: 1.32v
with low voltage prime 2 hours pass, and continue..
http://img207.imageshack.us/img207/9933/ud3p580pxe2.png
