Originally Posted by
Zehnsucht
I must say that the pin removal tool murdermod sells is very good. Just plug it in and pull out the cable. Extra force than you'd think is required of the pulling (I hear this is common in Corsair PSUs).
Just push the cable in as far as you can in the connector, while holding the cable push in the pin removal tool, then grab the connector (while the tool is inside and resting on the table) and pull out the cable. I found it very easy to do with a thick towel on the working table. Did two six-pins today, took almost five hours :)
Another tip is to do one cable, and then pull out the sleeving and cut 11 more (if doing two six pins) with the one as reference. This will make sure that all are of equal length.
