I take it VTT is 1.4v not 4 volts!!!!
Cheers for the info Paulo
http://i159.photobucket.com/albums/t...IGSCREEN-1.jpg
thats my current rig before volt mods (to be done soon and with a new e2140) :D
http://forums.vr-zone.com/showthread.php?t=192571
Seems there's an even better way to vmod the STL6714 controller - I recommend that this method be used over my own as you'll inject less noise into the circuit.
My 8800GT now works with my 775Dual VSTA
http://www.hardforum.com/showthread....1130608&page=6
Originally Posted by androo87
I got the ASUS GEN1 BIOS from the ASRock techs and risked it on my Inno3D card.
** My 8800GT now works with my 775Dual VSTA
Find the BIOS file and flash utility here:
http://www.yourfilehost.com/media.ph...ASUS8800GT.zip
I put the card in another motherboard, booted from my USB boot drive created using:
http://www.student.livjm.ac.uk/cmpsg...rive_guide.htm
Put the BIOS file and flash utility on the USB root drive and run:
nvflash as01gen1.rom -4 -5 -6
And now I'm hitting 8500 on 3dMark06 and running Bioshock at 1680x1050 with ease (and saved the £50 that would have gone a new mobo).
I think this is definately the best option for the moment if your 8800GT is not booting, but I dont gaurentee this will work..
Very nice, though this does mean, I have to find someone with a USB Drive as well as an available computer to flash the card I need to purchase since I don't have a second system.
Lost my mac address also, cant seem to locate it, can someone point me to the correct location of the mac address on my 4Core Dual Vsta board?
Ta Much in advance
Logan
The answer is in this thread post 25.
http://www.xtremesystems.org/forums/...d.php?t=117017
Nirvana Bios
Looks Like a hidden Via Bios exists that lets you changes all sorts of settings.
Could someone Techy please try it and explain what it’s all about.
Thanks Javver for making this known in another forum.
http://www.newegg.com/Product/Produc...82E16813157115
GEEKS.TECH
Tech Level: high
Ownership: 1 day to 1 week 11/30/2007 4:40:33 PM TECH AND TEST
Pros: IF YOU HAVE PROBLEMS WITH THE BORD TRY F9 DEL AND THEN LET THE BORD RUN A TEST WITH WILL TAKE ABOUT 2 HOURS ON A PENTIUM 4.1GHZ AFTER THE TEST THE BORD WILL ADJUST ALL THE SETTINGS WITH YOU'R SYSTEM --WARNING IF YOU RUN THE TEST AND NOT COMPLETE IT IN THE CON DOWN TIME AND YOU SHUT OFF THE SYSTEM YOU'R BORD WILL BE FRY'T BEFORE RUNNING THE TEST GO TOO BIOS AND FOR BOOT CHOICE NOTHING IT'S NO CD NO FLOOPY NO DVD NO HD DISK AND KEEP TRYING TOO RESTART THE SYSTEM AND PRESS F9 AND DELL KEY IF IT FAILS AFTER TRYNG IT MORE THEN 2-3 MINNUTES HIT THE F9-AND TAB YOU WILL GET IN A VIA BIOS NOT THE F2 BIOS THE VIA BIOS IT'S HIDDEN BIOS BUT CAN NOT BE ACCESS EASY IT TAKES TIME IT CAN TAKE HOUR'S PLESE DO NOT ADJUST ANYTHING IN THE VIA BIOS ONLY RUN THE AUTO TEST VIA BIOS HES LOT'S OFF FUTURES AND VOLTAGE ADJUSTMENT'S AND LOCKING FUTURES FOR F2 DO NOT OVERCKLOCK THE VIA BIOS DO NOT TRY TOO CHANGE ANY NAMES IN THE VIA BIOS LIKE THE MODEL NUMBER OR THE IBC NUMBERS OR THE SPCIPPNS VOLTAGE OR AGP
Cons: YOU CHOICE ALL ATT YOU'R RISK
Other Thoughts: IN THE VIA BIOS YOU MAY CHANGE THE FSB-1066-OR-800-533 AND YOU CAN ADD MORE FSB LIKE 1666 FSB OR MORE AND AFTER YOU ADD MORE FSB PLESE ADD THE MHZ FROM CPU AND THE MB SO THE PROCESSOR SUPPORT IT HIH GEEKS AND TECH AT ---NEWEGG,COM
TECH -AND TEST
Tech Level: high
Ownership: 1 day to 1 week 11/30/2007 2:30:53 PM BORD TECH
Pros: BORDS PERFECT 4 OVERCKLOCKING SUPPORT'S ALL PROCESSORS SOCKET 775 TESTED WORKS PERFECT THER IT'S A TRICK IN THE BIOS AND F9-AND DEL BUTTON WHER USERS CAN OVERCKLOK VIDEO MEMORY VIDEO VOLTAGE THER ARE MORE OPTION'S ON THIS MOTHERNBORD JUST CHEAK IT OUT CHANGE THE clrs TOO CLR AND PRESS THE START BUTTON AND PRESS TAB AT STARTUP AND UNLOCK THE WORLD WARNING OVERCKLOCKING THE VIDEO FROM 64MB TOO 10 GIG WILL FREY THE DDR OR DDR2 MEMORY SOO YOU CAN USE THE INTERNALL VIDEO MEMORY AND OVERCKLOCK IT TOO 1GIG SHARE MEMORY CLICK IT TICK IT
Cons: BORDS PERFECT 4 OVERCKLOCKING SUPPORT'S ALL PROCESSORS SOCKET 775 TESTED WORKS PERFECT THER IT'S A TRICK IN THE BIOS AND F9-AND DEL BUTTON WHER USERS CAN OVERCKLOK VIDEO MEMORY VIDEO VOLTAGE THER ARE MORE OPTION'S ON THIS MOTHERNBORD JUST CHEAK IT OUT CHANGE THE clrs TOO CLR AND PRESS THE START BUTTON AND PRESS TAB AT STARTUP AND UNLOCK THE WORLD WARNING OVERCKLOCKING THE VIDEO FROM 64MB TOO 10 GIG WILL FREY THE DDR OR DDR2 MEMORY SOO YOU CAN USE THE INTERNALL VIDEO MEMORY AND OVERCKLOCK IT TOO 1GIG SHARE MEMORY CLICK IT TICK IT
Other Thoughts: BORDS PERFECT 4 OVERCKLOCKING SUPPORT'S ALL PROCESSORS SOCKET 775 TESTED WORKS PERFECT THER IT'S A TRICK IN THE BIOS AND F9-AND DEL BUTTON WHER USERS CAN OVERCKLOK VIDEO MEMORY VIDEO VOLTAGE THER ARE MORE OPTION'S ON THIS MOTHERNBORD JUST CHEAK IT OUT CHANGE THE clrs TOO CLR AND PRESS THE START BUTTON AND PRESS TAB AT STARTUP AND UNLOCK THE WORLD WARNING OVERCKLOCKING THE VIDEO FROM 64MB TOO 10 GIG WILL FREY THE DDR OR DDR2 MEMORY SOO YOU CAN USE THE INTERNALL VIDEO MEMORY AND OVERCKLOCK IT TOO 1GIG SHARE MEMORY CLICK IT TICK IT CPU OVERCKLOCKT FROM 3.2 GHZ TOO 4.2 GHZ VIDEO FROM 64 TOO 776MB BIOS CHANGET FROM PCCHIPS TOO MOTHERNBORD.
Has this been tried/tested yet?
well it hadn't worked for me and the more I read that the more it sounds like a spoof post. F9 is the "load optimal settings" key, there never has been a Pentium 4.1Ghz processor, it shouldn't take several hours to "get into a BIOS" and the spelling is all over the place.
Red herring? :(
I've just modified my 4coredual-vsta board with the vmods in the thread and everything seems to work good. I have a few questions before I actually start insulating the board and making everything ready for some - kick ass - AGP benching.
1) Has anyone figured out the vDroop mod? Vcore is swinging too much for me
2) Has anyone got a clear picture of the readout points? I've found both vcore and vdimm points, but haven't found the vagp and vtt yet.
3) Latest bios = best bios? I reckon not and probably should read through the entire thread to know the answer. What are the modded biosses offering more instead of the official ones?
Massman I'm gonna add you to messenger - will be able to point out all the bits you need ;)
As for vdroop and vcore I recommend you see this:
http://img45.imageshack.us/img45/216/l6714mod5ou6.png
I'm not really fond of desoldering resistors and capacitors even though it might be better. Isn't there a normal, easy way to modify the vDroop? :)
:confused:
New 4CoreDual-SATA2 R2.0
http://www.asrock.com/mb/overview.as...TA2%20R2.0
The new R.2.0 board has a different and perhaps inferior sound chip than the R1.0.
R2.0
Audio - 5.1 CH Windows® Vista™ Premium Level HD Audio (ALC662 Audio Codec)
ASRock 6CH Premium I/O
http://www.asrock.com/mb/overv...4CoreDual-SATA2%20R2.0
R1.0
Audio - 7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
HD 8CH I/O
http://www.asrock.com/mb/overv...=4CoreDual-SATA2&s=775
