Which one are Seasonic?
All but the VX550 and VX750?
Or also the VX650?
If so, weird that only those two are made by another company? :confused: :rolleyes:
How come the Ultra X3 is not in the Tier 1 brands?
According to jonnyguru reviews it got better scores then some of the PCP&C and the silverstone ones.
VX-450 - Seasonic
VX-550 - Channel Well(CWT)
HX-520 - Seasonic
HX-620 - Seasonic
TX-650 - Seasonic
TX-750 - Channel Well(CWT)
HX-1000 - Channel Well(CWT)
Real Power Pro/M 750W and lower are good PSU's, similar to the iGreen, but updated a bit, the 850W and above are very high quality, built by Enhance.
It's a bird !! It's a plane !! No it's the tiered PSU list AND ITS BACK !!
(Blue tights and obnoxious Super Hero not included)
Enjoy, lmk what needs to be moved. I will take suggestions and additions to models that have come out but JG's got the last word on EVERYTHING.
Keep that in mind.
Perkam
were is the corsair TX with CWT is it with the silverstones in T1 or the thermaltakes in T2 with CWT
@perkman nice new avatar
Just one question, why is Delta rated Tier 4? I work in a computer shop and sell about 20 Delta ServerPower 650W power supplies a month. I have yet to see one fail, even in the hands of some extremely stupid people.
Plus the PSU is not modular, which is one thing i like.
thanks for reposting- i consider this the best listing available.
Here's the answer.......
Originally Posted by perkam
The list has almost been abandoned for over a year with no updates to reflect new power supplies, changes in OEM builds for different brands, or anything else.
To put it in perspective.....the Enermax Liberty series is listed in the same tier as Seasonic/Corsair HX/PCP&C Silencer builds (all essentially the same power supply as Seasonic builds all of them and they're all almost identical internally)...... yet the failure rate of the Liberty line is terrible....much worse than anything from the aforementioned Seasonic builds.
While the Liberty line has good specs, there is more to a power supply's recommendation than just good specs....durability and reliability should also factor into that, something Enermax's Liberty line cannot claim to have much of.
As an example....a recent review (4-13-08) of the Enermax Liberty DXX 500W garnered this praise from Hardware Secrets:
To be completely honest we were somewhat disappointed with Enermax Liberty DXX 500 W, as we expected more from it.
....its efficiency was somewhat low, being below 80% if you pull more than 300 W from it.
This power supply uses a different design on its secondary, which showed to be not so good. Together with the decision of using a single-transistor forward design on the primary instead of the traditional two-transistor forward, the design used by this power supply proved not to be the best for efficiency.
Also almost all protections failed during our tests, showing that they are either disabled or configured with a value that is too high: this power supply didn’t survive our overload tests.
We know that average users won’t probably overload their units, but it is always nice to know that the power supply will turn off if an overloading situation occurs, instead of just burning.
However, when you think that both Corsair VX450W and Antec EarthWatts 500 W are cheaper and better products – both are internally the same power supply and can provide a far higher efficiency and have their protections working just fine – it makes no sense buying Enermax Liberty DXX 500 W today.
ps.....the Liberty DXX burned up in testing........the same testing environment that a Corsair 620HX went through with not a problem what so ever.
Now, I'm not saying all Liberty DXX's are problematic....the 1kw unit seems great, but to lump all Liberties under the Liberty umbrella and categorize them along with many others of known excellent quality just does this list no good for credibility.
Do you know who makes Zalman PSUs? They seem to be pretty good. For what I’ve read, it’s a Korean manufacturer.
Jonny, did you ever figure out what OEM makes the Silverstone OP650? I got bored the other night so I was reading the review for my power supply on your site, and you said Impervio wasn't it.
awesome list, thanks for bringing it back perkam!
I wrote that review over a year ago and didn't know of Impervio back then.
Impervio is in fact that OEM. They use IS-Quasar's robotic facility to assemble their designs.
I have heard though that if IS-Quasar is behind on production that some of the units will be built by Etasis in a pinch.
So is all of that a good thing that it's assembled by robots? No human error is a good thing, no?
I guess your review shows that Impervio is a good OEM, but is the OP650 the only one made by Impervio?
Any of these PSU's good?
Bgears - Don't know them.
http://www.newegg.com/Product/Produc...82E16817426004
Mushkin - Not sure if this is an Enhanced model
http://www.newegg.com/Product/Produc...82E16817812005
ABS Tagan BZ Series BZ700 - I don't know which Tagan that coresponds to on the list
http://www.newegg.com/Product/Produc...82E16817814015
Thanks,
Utnorris
What PSU for SLI 8800Gts g92, q6600, 790i Ultra, 2x Barracuda 500gb??
It has to be modular and 750w or more!
Thanks!
http://www.newegg.com/Product/Produc...82E16817256009
will this be enough for my rig in my sig.The 620 just isnt cutting it
So what about the StealthXStream?
