if you still wanna OC dont use SATA1 & 2 ( still not locked ), maby you can buy a PCI SATA card or something for the hd you wanna add.Quote:
or jst get a PATA ddrive and plugg it in there.
Thanks for the replys.
Even if it's not the answer I wanted. :mad:
guess no one has x2 ?? but i idid a fresh install and no more bsod for now it used to load in safe mode and after giveio.sys it would bluescreen but i couldnt read the error. but on a good note i got my ram back and its doing 285 with no errors so ill push higher :->
[IMG]http://img262.imageshack.us/img262/8210/imga02760yz.jpg[/IMG]
[IMG]http://img486.imageshack.us/img486/6690/imga02781ga.jpg[/IMG]
got new heat spreaders too :D
[IMG]http://img483.imageshack.us/img483/9289/imga02793zc.jpg[/IMG]
all at 1t .. so it was the mem sideeffect :woot:
Originally Posted by sideeffect
i might have to take u up on that offer
this thread will never die too soon.... :P..a little offtopic :P
what vdimm and bios are u using msimax? those look like some nice sticks :)
What the hell?!
What is this new problem I have?
Can't hit HTT 280 ro avobe! I'm about to puke. What's the problem? What should I do? I easily could reach even 320 now stucking at 275.
What's wrong with this board? i didn't like it the first day i bought it.
You should have sent it back then.
Originally Posted by FlyingHamster
SE 1.cb3 tccd or something like that at 2.68v
Originally Posted by msimax
2.68? how? there is a setting for that voltage?
and i soldered a wire from the mb so i can adj down to 0.01v accuracy
Originally Posted by Mehran
maybe its the mem controler starting to fade! mine has on two 939cpus :mad:
yup ive had the memcontroller/cpu fade on 2 amd64 chips also.
its like if you overclock them and beat them real hard they are weak and they fade out. until you cant overclock very far at all.
both of mine faded down to about 250mhz max stable.
what happens if you lower the ram to 166 or 133 and run the same HTT or higher ?
hey all, well im stable at 2.9, bu i dont liek the amount of voltage i have to put to itt to get there. reason is becuz of the way the voltage fluctuates so wildy on this mobo. yall know of some way to add something to the board to steady the vcore out? let me know mane!
http://img454.imageshack.us/img454/1...ehot7nb.th.png
Hi,
I just installed the 1.BRev2 TCCD bios on my Neo2. Then i booted up and everything went well, but now when I want to get into bios the only thing that comes up when I press del is a black screen with a blinking line.
What should I do?
Borre ENABLE k/b storrage support. :toast:
hm don't really understand what you mean :/
where do I do that?
Go into bios and enable usb k/b storrage support. No flashing cursor
http://www.xtremesystems.org/forums/...13#post1038613 :toast:
No, I use a TT Big Typhoon.
That's exactly the same as I get, but I have no problem to boot into windows as long as I don't push del :/
sinister1st: Thanks a lot! I will try it in just a moment
@Ssider This is a problem with the new bios (on my board anyway). If he does a full shut down he will be able to go into bios, but on a RESTART :nono: upon entering bios you will get a blank cursor UNLESS usb k/b storrage support is enabled. I drove myself crazy when this happened to me :slap: :) but it worked. And i flashed the bios about 3 times and cleared the HELL out of cmos and its still there. Just a aggrivating bug i guess. I want to know if this happens to EVERYONE or just a few? I never got to see all the other errors that people were encountering like ENVOKE ROM or the other little goodies either.
sinister1st: Thanks a lot! It worked.
