256K chunks is not unlikely, it might be the actual block size for that NAND?
@adrianu
If the 830 is running with TRIM enabled you should be OK without reserving extra spare area. (over-provisioning)
It depends on what the drive is used for, normal usage you should be fine using the full capacity whether TRIM is enabled or not.
Without TRIM I'd personally set user-size to 110GB or thereabouts but it isn't required of course.
