I got to say though I really did like this board. I think for the money I had into it, it was worth every penny.Quote:
JPH is just bitter ... my board doesn't have problems with F8I ...
I am having problems with my Raid chipset on my GA-965P-S3. Each time I load a raid driver from the Gigabyte website I get a error.
wrong quoteQuote:
Originally Posted by kraggy
Isn't that special.Quote:
Originally Posted by ScythedBlade
You getting it from the Taiwan site or US? I have no troubles w/ the US hosted drivers...Quote:
F8i is running really well for me, too...but JPH isn't the only guy having problems with this board, and I probably would buy MSI or Asus if I had to do this purchase over. It seems like its a train wreck waiting to happen. I prolly jinxed myself now :eek:Quote:
I'm not flashing any other bios for this board, even final, until I see its safe to do so. Really, this "borked bios" crap really sux especially if you can't recover-restore old bios, and have to mess around wasting time and effort installing new mb's etc.
I like speed, but I value stability too.
Does anyone think the "D9 flaw" will affect running tighter timings with lower frequencies in addition to the "FSB/frequency" cap of around 460/920?
For example it is known that d9MGH will often run 3-3-3 at FSB 400 or at least 3-4-3 provided you give enough volts (2.3 volts usually works)
My Crucial Ballistix is running 3-3-3-12-16 at 533mhz on my nforce4 board. It would never run that tight on the DS3.Quote:
Originally Posted by Phosphate
I was able to boot with more than 2.375vdimm for the first time with f8c, still cant exceed 1.57vcore without big time instability tho. :/ (DQ6)
Anyone know if f8i will work on ds3 rev2 boards? I know they changed out the nic controller for the one in the s3. I'm assuming it'd be fine since people are flashing ds3 on their s3's. Not really bothered to flash from f7 though. Running 400fsb and 4:5 1000 4-4-4-12 2.3v at the moment. Vdimm set in bios is 0.1v less than actual set voltage for me.
lol take a chance and let us know ;)Quote:
Originally Posted by ziddey
is the Rev2 DS3 anywhere her ein the USA yet ?
or should i say DS3P Rev 2
Patriot RAM isn't D9. Maybe I should pick up some Patriot and end my misery?Quote:
There still seems to be confusion about rev2 boards.
There is a DS3 Rev2 and a DS3P rev2. They are much different boards.
The DS3 Rev 2 has shipped sporadically from newegg over the last month. You can't be sure yet which one you will get. I am hoping my replacement ends up being a rev 2.
well i meant to say the DS3P
the rev 2 ie; DS3 w/ C2 chipset is no better than the original DS3 as it still has D9 issues.
i dont think we will see the DS3P for another 2 months considering how long it took for the Biostar board to show up here in the USA
Originally Posted by Lestat
I have a DS3 with the C2 chipset and F8I and F8J still don't hold the overclocks if that was what he was wondering...
For the time being I went back to my P5B-E. I'm not a patient person.
Look who's back ?! ;)Quote:
I've ordered a revision 2.0 for the DQ6, i've seen two reports of folks on Newegg getting a rev. 2.0 for the DS3, the DS3-P is on sale...at least in Europe.
GB have updated the bios ROMs in the new beta bios, 1.06.59 for JMicron, i'm assured the Intel ROMs will also be updated.
Yeah I got my rev2 from newegg.Quote:
And what d9 issues? I seem to be doing fine
See my sig... ;)Quote:
Edit: should note I got a €500 ocz d9gkx kit which doesn't clock higher then that €120 geil powerchip kit it's in my sig on another forum.
So what would be the best DS3 bios to use at this point with an S3 mobo? Still stuck around 400mhz FSB with the F6 bios... Can't give the vmem more than +.2 (2.0v) or the board wont get past the memory running dual channel part of boot... My hardware isn't the issue, as I've hit 460mhz FSB on a P5W DH with the exact same hardware at 8x multiplier, and was limited by the board...
F8I or F8J as long as your PC is on 24/7. Otherwise F7 sucks for OC but at least it holds the overclock.Quote:
Originally Posted by Hutch
Perfect for me! I've shut down my pc once since I moved into my own condo 2 months ago. The only reason I shut it down was because well... I was forced to, the power went out!Quote:
Originally Posted by dnottis
I just realized how much heat this NB is giving off, probably more than the one on my asus nforce4. Just used a digital thermometer from an old HD cooler w/ temp sensors to measure it, it read 71*c and my cpu is idle... Just threw an 80mm fan on it and could smell the plastic of the fan burning for a little while (I run everything off the bench, no need for a case!)
Ahhh much better now. Time to try the new bios... Can I flash via @bios or do I need to do it via floppy since it's a different boards bios? I know GB has some idiot proofing with their bios flashing...
@bios in Winders is fine. :D
Grab a $7 50MM fan from Newegg, brought my NB back to slightly above room temp.
It has been way too long in coming but we should have a final F8 for the DS3 here on Friday or at least the new qualification candidate. Once we get it, I will post it up.
