Thanks a lot. I hope this will do the trick. Setmemscreen follows
Code:
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 x ]
Fine CPU Clock Ratio............................[ + .5 ]
CPU Frequency 3.825GHz..........................[ 450x 8.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 450 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.........................[800mV]
PCI Express Clock Drive.................[900mV]
CPU Clock Skew..........................[ 0ps]
MCH Clock Skew..........................[ 0ps]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
MCH Frequency Latch.............................[ 400 ]
System Memory Multipler.........................[ 2.00D ]
Memory Frequency 1066...........................[ 900 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Disabled ]
CPU Vcore [ 1.25 ]......................[ 1.26875v ]
CPU Termination [ 1.20 ]...................[ 1.20v ]
CPU PLL [ 1.50 ]...................[ 1.50v ]
CPU Reference [ 0.760 ]...................[ 0.760v ]
MCH Core [ 1.100 ]...................[ 1.220v ]
MCH Reference [ 0.760 ]...................[ 0.760v ]
MCH/DRAM Reference [ 0.900 ]..................[ 0.950v ]
ICH I/O [ 1.500 ]...................[ 1.5v ]
ICH Core [ 1.100 ]...................[ 1.1v ]
DRAM Voltage [ 1.800v]...................[2.000v]
DRAM Termination [0.900v]....................[1.000]
Channel A Reference [0.900v].................[1.000]
Channel B Reference [0.900v].................[1.000]
Performance Level as already mentioned is 9 (Rest Auto) anything lower results in a non-bootable system.
As stated above the RAMs are G.Skill 4GBPQ DDR2-1000. Can`t give it to you more concrete if you wish to know which Chips are on them. Sorry mate
