Originally Posted by
GFORCE100
I've noted you stating the same a few times about how the MIIF and your RAM don't want to play ball and I'm baffled since as you know from my sig (which has been present for a year now or so), the MIIF is just fine with Micron RAM at 1200MHz effective. Also bare in mind I'm running 4 sticks of it.
I've done 50x of Linx (IBT) on it with all the RAM options checked and it's fine. It's passed MS memory check for ages (over 50 passes) and that also proved it was OK. All this at 2.15V and the timings in my sig - all other RAM options are on auto or disabled except for performance level, transaction booster etc.
The MIIF is definitely sensitive to the RAM BIOS settings, it's very easy to break stability. In fact the BIOS is buggy since if it wasn't for the cold boot problem (black screen), I could run my RAM at 5-4-5-18-30 at 1200MHz which gets the latency down to about 50.5ns in Everest.
