Originally Posted by
carmatic
do you mean you have the 714 bios? im not sure which bios version i have
'clock my sticks lower' , that means use a lower divider? or lower my fsb?
also, i think i have found a good way of dealing with the bowing of the board from not using a backplate when you have the cpu heatsink or waterblock on too tight... i had some silicon fan push-through mount things i got from one of the 'silent fans' ive bought and i stuffed them right under the edge of the motherboard where it was bowing the most, straight up from where the cpu socket is, and the pressure from these things is enough to push the board straight... i also stuffed a couple under where the pwm area is so that the heatsink over there will have more pressure with the pwm chips, because the bowing from the pressure of the cpu mounting can bend the pwm chips away from the heatsink
::edit:: dang, the first core failed prime after 1 hour with my southbridge voltage at 1.54v...now trying with a lower vtt and vcore setting, maybe my gtls were abit too low to be stable at the voltage i was using before this, and maybe a lower vtt would match up with them nicely... setting the host slew rate to 'strong' really did make a difference, wouldnt have known that if it werent for you guys
