Just got my Opteron 165 CCBBE 0615DPMW for 142 euro's
Running Dual Prime Torture test for three hours now at 2933MHz @ 1.344v :D
Forgot to add that when the box came from newegg it was a CCbbe 0610DPMW. :woot: :banana: :D Apparently newegg has a case of lcb9e's and a case of ccbbe's and they are parseling them out or something.
Orthos ran 15 minutes with no errors at 2.8 ghz 1.33 v, 43-45c under load with only the amd thermal pad from the sink. The spreader is very concave so I'm surprised it is so cool with the pad. I stuck the cpu up to an old sink and twisted it a bit. It only left scratches from the corners of the spreader. After some as5 it should be really cool. Totally thrilled so far. Half life two lost coast bench went from 103fps to 148 just by going dual core +200mhz clock.
At one point my temps were running 53 c then I noticed the cpu fan wasn't running. Header 4 on my dfi may have died or hopefully a short in the cable maybe. Twin 80's on my ram kept the cpu cool enough that it could still run I guess. Idling at 30c now.
ehehehe :toast:Quote:
Originally Posted by Magnj
I found the lowest vcore limit for 2700 mhz: 1.375v
http://img407.imageshack.us/img407/6...rimeja0.th.jpg
temps are 31/42. I ran spi 32M, some games and video encoding too ... I think it's not bad.
For only 200 mroe dollars youc an get a nice single stage phase change.Quote:
Originally Posted by Classic Satch
Lol, I'm not that crazy. My wife would have my gonads in a vise if I pulled something like that. I currently running Orthos on my 165 @334x9 1.475vcore and I'm about two hours in. I'm keeping my fingers crossed.Quote:
Originally Posted by CaptainLog
what are your temps at now @ 1.475 vcore?Quote:
Hovering right around 40C, fluctuating a degree or two in either direction.Quote:
Originally Posted by Burnt_Ram
thats pretty good, and this is using core temp tool?Quote:
Maybe its time guys to inform somehow the first post of the thread about the new steppings of the market..? would be very usefull to people who want buy now ..
Yep, Core Temp. I had to boost it up 1.5vcore and am now testing that. Temps are ~41-42C. Given that these chips are rated for 110W stock and giving it 1.5v drastically increases heat, I think that those are pretty darn good temps.Quote:
Remove IHS;)Quote:
Originally Posted by Littleluk
Remove IHSQuote:
Originally Posted by Ya3su
:D
Here is my experience with removing IHS:
http://img217.imageshack.us/img217/9...00primejl4.jpg
right now:
http://img407.imageshack.us/img407/5877/momentiu0.jpg
nice temps and OC Ivan. what are you using for cooling?
hi, just a question when ocing the opty,
1st step I tested HTT 250MHZ, ORTHOS 10 hrs not error, MemTest 11PASS and SuperPI 32M passed as well.
So can I assume that as long as my RAM speed will not over 250MHZ by using divider, NO other ram settings like Drive Strength, DRAM Voltage need to be changed no matter what HTT is?Code:Genie BIOS Settings:
FSB Bus Frequency............................. - 250
LDT/FSB Frequency Ratio....................... - x 3
CPU/FSB Frequency Ratio....................... - x 10.0
PCI eXpress Frequency......................... - 100Mhz
CPU VID StartUp Value......................... - AUTO
CPU VID Control............................... - AUTO
CPU VID Special Control....................... - AUTO
LDT Voltage Control........................... - 1.30v
Chip Set Voltage Control...................... - 1.60v
DRAM Voltage Control.......................... - 2.74v
DRAM Configuration Settings:
DRAM Frequency Set............................ - 200=RAM/FSB:01/01
Command Per Clock (CPC)....................... - Enable
CAS Latency Control (Tcl)..................... - 3.0
RAS# to CAS# delay (Trcd)..................... - 03 Bus Clocks
Min RAS# active time (Tras)................... - 07 Bus Clocks
Row precharge time (Trp)...................... - 02 Bus Clocks
Row Cycle time (Trc).......................... - 07 Bus Clocks
Row refresh cyc time (Trfc)................... - 14 Bus Clocks
Row to Row delay (Trrd)....................... - 02 Bus Clocks
Write recovery time (Twr)..................... - 02 Bus Clocks
Write to Read delay (Twtr).................... - 02 Bus Clocks
Read to Write delay (Trwt).................... - 03 Bus Clocks
Refresh Period (Tref)......................... - 4708 Cycles
DRAM Bank Interleave.......................... - Enabled
DQS Skew Control.............................. - Auto
DQS Skew Value................................ - 0
DRAM Drive Strength........................... - Level 7
DRAM Data Drive Strength...................... - Level 2
Max Async Latency............................. - Auto
DRAM Response Time............................ - Normal
Read Preamble Time............................ - Auto
IdleCycle Limit............................... - 256 Cycles
Dynamic Counter............................... - Disable
R/W Queue Bypass.............................. - 16 x
Bypass Max.................................... - 07 x
32 Byte Granularity........................... - Disable(4 Bursts)
Because I used those ram setting above when OCing up to HTT 305MHZ, then stuck in HTT 310MHZ, adding VCORE didnt help but instead need to change RAM setting even my RAM is running under its default.
ALso, in 310MHZ HTT, it passed ORTHOS Blend test priority 9 for 9 hrs, but seems could not pass the superPI 32M, is it mostly ram issue??
it's not stable but it can run a spi 1M
334x9 3006 @ 1.456v air cooling (XP-120) ...
http://public.yogurtrat.com/thumbs/1446334x9.JPG
Thanks, its aircooling Sonic Tower + 120 mm fan +artic silver 5 - IHS :DQuote:
Originally Posted by mike047
9x302 on stock air, 1.42v. 1/2hr OCCT. Chaintech VNF-4ST
It might make a good cruncher after all:)
hmm IHS removal is tempting
yes it is, but i'm scared i will foobar my chip!Quote:
and its a keeper for a change ;)
How can i remove IHS?
at BIOS?
by software?
Where is it?
sorry but i don't know what it is
quoted :slobber:Quote:
winner is...
the IHS is the heat spreader that is on top of the processor. if you remove it the cpu's core's are exposed, and the heatsink will make better contact resulting in better temps.Quote:
http://wowgame.free.fr/Opteron%20170/DSCF0005.JPGQuote:
I'm with you. I've ran Orthos for over 14 hours at 323x9 with 1.425v on my DFI. I'm currently testing 334x9. I believe that my chip is definitely a "keeper" but damnit, I want that 3.0Ghz. The thing is, I paid about $2300 in March 2006 for my current system and I just wish it to stay viable until Crysis comes out. I sold my former Opty 175, only hit 2.7Ghz, on eBay for EXACTLY the same cost that I paid for this BRAND NEW Opty 165. Thank God, otherwise the wife would have had a fit.Quote:
Well, not really, her title starts with a DR. Not medical but pharmacy. Less hours, company-paid liability insurance, and still a ton of money. :)
