Running 4GB at 975 fine here.
I still have huge voltage drops even with these bios, Check it. My Memory went under 1.0 volts :shocked:
http://i31.photobucket.com/albums/c3...20-Chipset.png
http://i31.photobucket.com/albums/c3...h20-Memory.png
Anyone out there who can help me with my X-Fi not working in first PCI Slot (above gfx) ?
Use Everest. In the Everest Preferences you can setup which sensor information it can send to other applications. And in OCCT pick Everest and setup the sensors. Just make sure Everest is always open before OCCT or OCCT will lose it the settings for monitoring... :(
What is changed in 0902 bios?
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...ula/MF0902.zip
I'm prime stable here with qx9650 at 4400mhz 1,5Vcore under liquid, anyone have this cpu with this mobo?
Haven`t got that voltage drops when runnintg OCCT, but ionly with a C2D, perhaps, it`s a quad problem!?
Or your board, or psu?
I'm on a Quad and I don't get the voltage drops...
[QUOTE=Warboy;2589590]I still have huge voltage drops even with these bios, Check it. My Memory went under 1.0 volts :shocked: [QUOTE]
0902 BIOS?
Sorry I don't read all posts. I don't seem to have all these problems. I just really look to make sure new BIOS are good before I flash. And try to give some advice when I can.
Warboy,
so you are reading out the voltages with a program?
Wouldn't trust this a 100%, so relax.
Oscilloscope anyone? :D
is there any bios setting that need to be set for crossfire to
work on this mb
thanks
Good point, but thats why i want everyone to try it. If its the program, Everyone will get the same problem. I've already thought through it ;)
I'm telling OCCT to read volts and temps from Everest. So everyone that has everest, and OCCT Beta. See if you get these same problem on any X38 board.
Components: ASUS Maximus Formula, Intel QX9650, Corsair Dominator PC8500, Western Digital Caviar 320GB, Sapphire 3870 (2), Enermax Galaxy 1KW, Dell 3007
I put all this together yesterday, and am having very strange problem. I can only describe it as trying to watch a DVD on your tv, with the tv on channel 4 when it needs to be on channel 3. The display is split in half horizontally, with either the bios or desktop displayed in both the top and bottom sections. The display flashes in and out, and is striped vertically with pink and white stripes. I got it to go away only on the desktop by cranking the resolution up. But the bios still does it. The problem was there with the shipping bios 0401 I think, and is still there with 0901 (latest?)
I have installed all chipset drivers and VGA drivers, even did a new install of XP, and am stumped on what to do next.
@GunslingerOCS: So you are using both PCIe x16 slots and a sound card, which slot above or beneath gfx card ? I didn`t tried the slot beneath yet because my Raid controller gets real hot and i don`t want to heat it up even more by putting another card under it. Fact is i can`t get my X-Fi to work in the first PCI slot, can you ?
