My cpu reach 60 degrees too passing ORTOS test, watercooled with danger den TDX. And the PMW IC chip at 70ēC :explode2:. my cpu is at 325*8 at 1.45v. But the stress prime ORTOS failed at 4 hours.
I think its for high temp.
sorry for my english...
Opteron 170
http://valid.x86-secret.com/show_oc?id=160717
Vcore +0.25. Air Vanessa L.
CCBBE 0615EPMW
Ya3su, I'm not comfortable at all with 60 degrees on water...less volts!
dissy? o_OQuote:
Originally Posted by XiN
i'm pushing 60c on air! lol, it can handle it ;)Quote:
Originally Posted by Magnj
It looks like I have a winner on my hands. I'm currently Orthos' testing my new 165 at 312x9, stock voltage. My Core Temp readings are 28C stable. I think that I'm going to easily hit 3Ghz but I'm taking this nice and easy. :banana:
http://img409.imageshack.us/img409/5381/opty0pj.jpg
I meant which heatsink, sorryQuote:
I used an italian-english word :D
what are you cooling with, and did you take the IHS off?Quote:
Originally Posted by Classic Satch
I'm using a Coolit Freezone and the IHS is still attached. My wife would kill me if I threw $150 down the toilet because I wanted my CPU to be a few degrees cooler. :) My ambient room temp is ~19C.Quote:
Originally Posted by Burnt_Ram
is that 28c load, or idle? i read a review on that "coolit freezone" and it was a good review. the unit is pricey tho. 399.00 usd on the review i read. i'm nterested in getting better cooling ;)Quote:
If you look at the screenshot you can see that the temps are under large FFT Orthos load. Idle temps are around 12C. I grabbed my Freezone for $250 brand new off of eBay. They are incredibly easy to install btw.Quote:
Here's another one:
http://cgi.ebay.com/FREEZONE-CPU-Liq...QQcmdZViewItem
where does the TEC draw it's power from, the computer's power supply? i have an old swiftech heatsink with a peltier (TEC) under it, but the power it drew, OMFG!Quote:
The Freezone uses a 3-pin connection for the pump and a standard molex connection for the rest of the unit. Under full load, the Freezone draws a maximum of 56 watts. My PSU is top-notch, it'll actually put out 650W but PC Power & Cooling rates theirs differently, so I don't sweat it.Quote:
thank you for all the info. much appreciated!Quote:
No problemo.Quote:
i had a look, andthe best price i can find for what you have is 351.00 CDN, so i think i might get this for 309.00 CDNQuote:
http://www.ncix.com/products/index.p...cture=Swiftech
Go for it. It's doing the job for me quite well and is very easy to install. Just make sure that you have very good case cooling because it's drawing air past it's radiator from inside the case.Quote:
3 intake, 3 exaust :) i'm going to mexico in a couple weeks, so when i get back i'm going to order it :cool:Quote:
One tip, you might now want that much exhaust flow. You don't want to starve the Freezone of air for it's fan. I had a high-speed 120mm directly below my unit and I wasn't getting the temps I wanted. I removed it and temps corrected themselves.Quote:
BTW, don't drink the water in Mexico!
That water cooling setup should do better than air for you but it will not come close to the FreeZone for only 42 more bones.
Ah, you Italians.Quote:
Io parlo piccolo Italiano ;)
I'm using an Arctic Cooling Freezer 64 Pro
Looked at a c2d system and the performance would probably be better but the upgrade would have cost nine bones. Decided to go dual core opty as I wanted one forever. Last year I got a single core 146 in hopes of getting 3ghz but only got 2.6 ghz@1.475 which really isn't bad.
ordered on 1/23/2007 4:37:35 PM from Newegg and chose Fedex next day and the 3 buck rush order feature. Shipped yesterday from the TN warehouse.
Last night I started finding out about the lcb9e's and was kind of worried since I never get a good stepping. Although I don't think they suck as bad as some make them out. I resigned my self to get the most out of it regardless.
ya, you figure the freezone will out perform the swiftech water setup. i wouldnt have thought so, but Classic Satch does have some nice temps! so i dunno ;)Quote:
Originally Posted by markr
Well I am on air so I NV either one.:slobber:
I do plan on obtaining a FreeZone soon. I just wish it was 120mm instead of 92mm.:mad:
I just purchased a ccbbe 0615epmw 165 Opty. Prime'n 2.9 @ 1.46V. Paid 200$ CAN :).
*edit* 3Ghz
