Some initial results on my CCBBE 0610DPMW.........
2.8ghz 1.32v (1.35 BIOS) 12h+ ORTHOS :) Gonna try droppin the voltage to 1.3v, and see how far she goes.
I have exactly your CPU (just arrived from UK): CCBBE 0616XPMW.Quote:
Originally Posted by Burnt_Ram
Which bios do you use?
:nono: you're supposed to UP the voltage and make it scream! :fact: :p:Quote:
Originally Posted by G4h4o8s6T
for my mobo, i use E05 ?Quote:
Originally Posted by XiN
ya, your's is an exception i think. i personally havent seen our stepping do less than 2.8. except for yours :confused:Quote:
Originally Posted by Varmint
ops sorry, I think you had DFI LP :p:Quote:
I'm getting my 165 CCBBE 0615 DPMW today. I have a DFI LP UT SLI-D motherboard and wanted to know if there's any particular BIOS version out there that people have had success with. Any input would be truly appreciated. :)
Edit: I have 2GB of G.Skill HV series PC4000 RAM. They use Infineon CE-5's.
:confused: I thought it was the other way around........drop the voltage and see how high it clocks??? :p:Quote:
Originally Posted by biohead
Though it does seem that way with these CCBBEs. :stick:
I just popped it in last night, so give me a break, Ill get her crankin later on tonight or tomorrow. ;)
I will hopefully be getting one of the Newegg ones next week, has anyone tried for 3.0 on a DFI NF3 Ultra D Yet? I am hoping that she will scream just like the NF4's do but I was just trying to get some feed back.
Hmmmmm isnt the NF3 Ultra-D socket 754??? :confused:Quote:
Originally Posted by jjeffreys
939 "AGP"Quote:
165 received today from New Egg, Tenn. warehouse;
LCB9E 0646 RPMW
it's for a cruncher, anyway.
Does anyone have an idea how CCBWE 0633XPMW performs?
Seems that most Dutch resellers are now selling this latest batch from AMD
Opteron 165 CCBBE 0616XPMW
DFI LP NF4 Ultra-D bios NF4LDB14
2x512 GSkill 4400LE
air cooling (XP-120 + Akasa 120mm @ 1300)
quickly test, 300x9 = 2700 mhz 1.4V
spi 32M
http://public.yogurtrat.com/thumbs/6...914vspi32M.JPG
2 x prime
http://public.yogurtrat.com/thumbs/9...x914vPRIME.JPG
As was posted, the NF3 is the Ultra D with AGP vice PCI. As far as I have seen there are no issues with running the opterons with them but I have not seen any data on how well they are clocking. I do know that my Venice clocked the same as others with the NF4 Ultra D so I am anticipating that the Opty should do the same. In any case I will let everyone know how my results are. The first thing I need to do is find someone that is willing to sell their 0610DPMW to me.Quote:
man, I owned 4 dual cores, and not a one did better than my original 3200+ venice. 2.7ghz was max. Must of just had bad luck.
I got me a new 165 from dustinhome.se in Sweden. Its a CCBBE 0615MPMW, I got a bit scared when I read that it was supposed to be one of the worst steppings :(, but now its dual prime'ing @ 2,5 ghZ with 1,35 volts, so far so good :D
EDIT: 2,57 ghZ @ 1,39 volts, don't know if its my mobo limiting me, or if its the cpu :(
@david901101: Crank up the voltage, maybe 1,45?
Mine is running stable with 2.9 @ 1,45v, 0615 EMPW. Its getting so damn hot, what the hell - Core 0 has 60, Core 1 even 66 Degrees. And that with water and open case! I've already remounted the waterblock several times, no success.
I think I'm gonna need 1.55 for 3,0 - is that too high?
1.6v is o.k. with water if you keep your temps in check.
whats your watercooling kit?Quote:
Originally Posted by Littleluk
might need to de-lid your opty
whats safe for these chips temp wise on air? I hit like 48 @ 300x9 @ 1.31V
Also anyone have any issues getting past 300mhz fsb on DFI NF4 Ultra? Seems if I budge it to 305 it has a fit...
I pushed my Opteron 175 just a little bit more. I don't want to push it any further without water cooling or better. Core temps getting too high for my liking. But it is prime stable for 10+ hours using normal indoor air cooling (70F/21C room temps.) So I'm happy. Now I can definitely wait for K8L, AM3 or whatever else is coming down the pike. Note that I have not removed the IHS and the case was closed for the entire dual prime duration ... meaning it was set up for everyday use.
DFI LANPARTY nF4 Ultra-D - BIOS 4/06/2006
AMD AMD Opteron 175 2x1MB L2 Cache, CCBBE 0617EPMW
Thermaltake Big Typhoon
OCZ Platinum Series 2x1GB DDR400 PC3200, Model OCZ400204BELDCPE-K
OCZ Powerstream 520W PSU
MSI 7800GTX Geforce 256MB PCI-E x16 Video Card (473/1279)
1 Segate Barracuda 120GB IDE 7200RPM 8MB Cache HDD
1 Segate Barracuda 160GB SATA 7200RPM 8MB Cache HDD
2x Segate Barracuda 160GB SATA 7200RPM 8MB Cache HDD in RAID 0
Lite-On IDE DVD/CD-RW Combo Burner 2MB Cache
Mitsumi Floppy Drive
Code:Genie BIOS Settings:
FSB Bus Frequency............................. - 284
LDT/FSB Frequency Ratio....................... - Auto
CPU/FSB Frequency Ratio....................... - Auto
PCI eXpress Frequency......................... - 100Mhz
K8 Cool' n' Quiet Support..................... - Auto
CPU VID StartUp Value......................... - 1.450
CPU VID Control............................... - 1.500v
CPU VID Special Control....................... - Auto
LDT Voltage Control........................... - 1.20v
Chip Set Voltage Control...................... - 1.70v
DRAM Voltage Control.......................... - 2.80v[/color]
DRAM Configuration Settings:
[color=red]
DRAM Frequency Set............................ - 150=RAM/FSB:03/04
Command Per Clock (CPC)....................... - Enable
CAS Latency Control (Tcl)..................... - Auto
RAS# to CAS# delay (Trcd)..................... - Auto
Min RAS# active time (Tras)................... - 07 Bus Clocks
Row precharge time (Trp)...................... - Auto
Row Cycle time (Trc).......................... - Auto
Row refresh cyc time (Trfc)................... - Auto
Row to Row delay (Trrd)....................... - 02 Bus Clocks
Write recovery time (Twr)..................... - 02 Bus Clocks
Write to Read delay (Twtr).................... - 02 Bus Clocks
Read to Write delay (Trwt).................... - 04 Bus Clocks
Refresh Period (Tref)......................... - 3120 Cycles
DRAM Bank Interleave.......................... - Enabled
DQS Skew Control.............................. - Auto
DQS Skew Value................................ - 0
DRAM Drive Strength........................... - Level 8
DRAM Data Drive Strength...................... - Auto
Max Async Latency............................. - Auto
DRAM Response Time............................ - Fast
Read Preamble Time............................ - Auto
IdleCycle Limit............................... - 256 Cycles
Dynamic Counter............................... - Disable
R/W Queue Bypass.............................. - 16 x
Bypass Max.................................... - 07 x
32 Byte Granularity........................... - Disable(4 Bursts)
Prime95 + 3DMark2001SE + CPU-Z:
http://img293.imageshack.us/img293/3...1se31244yd.jpg
nicely done, wish I had at least one more multi at my disposal :-/
Thanks ... I take no real credit, though. I just got really lucky with the stepping and the chip. I love this chip!! Yeah the 11x multi sure does help me since my RAM is pretty slow.
Which dissy do you have? I think 48 it's safe. I do 45° (dual prime) at 300x9 1.392V with XP-120 and 120mm @ 1400 rpm.Quote:
Originally Posted by Magnj
I had few tests and it isn't actually easy getting past 300, but I think the problem is mem divider and ram.
