Yeah, that's what I'm afraid of is the thermal tape removing an IC. I have my Corsair Dominator fan on them. I'll have to take the laser temp thingy home from work and measure temps.
I'm planning to upgrade my kids board to an EP45-UD3L, since it's cheap. I'm wondering does it also run the P45-A3 chip? TIA! :-)
Yes it does, I just built one for my boss's office PC. I used that board and E7400 with some Corsair XMS DDR2-800 2x1GB sticks. I ran it at either 400fsb x9 for 3600 or 425fsb x8 for 3400 with RAM 1:1 and it was quick! I could have ran it higher but didn't as it he wouldn't of noticed. I would recommend replacing the stock cooler and using a case with some room for a couple 120mm fans. 1 for front and 1 for rear as usually but if you can get one on the side to blow at the motherboard that would be great!
I never posted my results of my Q9650 @450x9, well, here it is.
http://i21.photobucket.com/albums/b2...oursprime4.jpg
took me 3 weeks to fully stablize it but now it 100% stable :)
http://valid.canardpc.com/show_oc.php?id=570716
http://img33.imageshack.us/img33/248...5201513.th.jpghttp://img39.imageshack.us/img39/705...5201514.th.jpghttp://img33.imageshack.us/img33/651...5201515.th.jpghttp://img43.imageshack.us/img43/854...201516p.th.jpg
http://img34.imageshack.us/img34/263...estdata.th.jpghttp://img32.imageshack.us/img32/598...tdataoc.th.jpg
http://img194.imageshack.us/img194/2...perpi1m.th.jpghttp://img194.imageshack.us/img194/1...perpi8m.th.jpghttp://img188.imageshack.us/img188/8...erpi16m.th.jpghttp://img42.imageshack.us/img42/30/superpi32m.th.jpghttp://img32.imageshack.us/img32/238...lection.th.jpg
http://img38.imageshack.us/img38/6358/cpugpuz.th.jpghttp://img39.imageshack.us/img39/492...tabench.th.jpg
http://img132.imageshack.us/img132/4...lstable.th.jpghttp://img32.imageshack.us/img32/138...dstable.th.jpg
http://img38.imageshack.us/img38/663...lstable.th.jpghttp://img38.imageshack.us/img38/436...dstable.th.jpg
http://img32.imageshack.us/img32/331...emptest.th.jpghttp://img132.imageshack.us/img132/6...hedtemp.th.jpg
http://img32.imageshack.us/img32/275...alyst95.th.jpghttp://img38.imageshack.us/img38/267...alyst95.th.jpg
For you extreme overclockers....something better than AS5 !!!
http://www.frostytech.com/permalink.cfm?NewsID=76368
http://indigo-xtreme.com/comparison/comparison.htm
I would like to know, ehich one is for you the last stand for vcore on a quad for 24/7 on air??
Thanks radaja! Thanks to Sergio for helping me make the transition from the M2F to the UD3R!
yea i did the exact same thing.only it was by accident.i went from the P5Q-deluxe,in hopes of something better(i thought if it cost more it must be better)so i got the M2F.but i died and as luck would have the day newegg first got and posted the UD3P for sale i was looking for a cheap board to hold me over till my M2F got back from RMA.and what a surprise these boards turned out to be.
half the price and two or three times the performance.anyways your in good company here.a lot of happy and helpful members here to help out,but it looks like your doing great as is:up:
keep us updated on your 9650-UD3R endeavours
looking good already:D
Osterman, try this:
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 9
CPU Frequency .........................: 4.0GHz (445X9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 445
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control
CPU Clock Drive........................: Default (800mV)
PCI Express Clock Drive................: Default (900mV)
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 0ps
DRAM Performance Control
Performance Enhance....................:Standard
Extreme Memory Profile (X.M.P.)........: Disabled
(G)MCH Frequency Latch.................: Auto
System Memory Multiplier ..............: 2.40b
Memory Frequency (Mhz) ................: 1068MHz
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control. Performance level= Static tRead Value, Make sure you set the "Static tRead Value" in both channel A & B timing settings to 8
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Enabled]
CPU Vcore..............................: 1.30v
CPU Termination........................: 1.28v
CPU PLL................................: 1.50v
CPU Reference..........................:0.835
MCH/ICH
MCH Core...............................: 1.30v
MCH Reference..............................:0.850
MCH/DRAM Ref...........................: Normal
ICH I/O................................: Normal
ICH Core...............................: Normal
DRAM
DRAM Voltage...........................: 2.10v
DRAM Termination ......................: Normal
Channel A Reference....................: Normal
Channel B Reference ...................: Normal
If that doesnt work try going up one notch on your MCH Reference to .890
If that doesnt work bump the MCH ref back to .850 and try going up a couple notches on your CPU Vcore. If it still fails, set everything back to stock and open prime and let it run a couple hours. If your 1066mhz ram fails at 1066mhz with no overclock then you know the problem. Or just run memtest.
I have 3-45nm quads and all will do 4.0ghz on less than 1.30v vcore (bios), I think it is your settings or like you said, your Ram
Under Advanced BIOS settings, at the bottom. Set "Init Display First" to PEG, default is PCI. Maybe nothing but on my GTX I freeze or crash if that is set to PCI not PEG.
well i am so damn happy with my new E8400 EO vid 1.23.now that i got another kit of cellshock pc8000 im having more fun and more options.
i decided to see what the lowest vcore i could use at 9x445@4005 and it turns out that i can drop it down two notches below default vcore:D
and the cellshock at almost ddr1200 with only 2.08vdimm:up:
so heres 9x445@4005 with 1.21 bios/1.18 cpuz load ddr1186 w/2.08v
http://i40.tinypic.com/dnzsld.jpg
i just tried 450x9@4050 w/1.18v and ddr1200 w.2.08v
and it's priming just fine :D:up:
http://i43.tinypic.com/kf1f2d.jpg
THIS CPU ROCKS:D
Did a little more testing now with IBT....
http://i21.photobucket.com/albums/b2...20tests1-2.jpg
I tried running my MCH lower, 1.38v and upped my vtt to 1.28v. But i got an error, I guess I need 1.40v MCH....
yes on my system i have to go for 1,4MCH as im always over 1170Mhz with the Gskill on Turbo Profile, if i remember you are on turbo profile also mate, maybe it can handle it good if you go for standard, but with thight timmings it'll ask for more at least in my case...
cheers :up:
Sergio
heres a couple of Pi runs with my new cellshocks.
1m Pi 9x500@4500 w/1.32v ddr1200 pl8 w/2.18v
http://i40.tinypic.com/3509u8p.jpg
32m Pi 9x500@4500 w/1.32v ddr1200 pl8 w/2.18v
http://i44.tinypic.com/55rm2e.jpg
1m Pi 9x512@4608 w/1.34v ddr1228 w/2.2v
http://i40.tinypic.com/fz9o48.jpg
32m Pi 9x512@4608 w/1.34v ddr1228 w/2.2v
http://i40.tinypic.com/x1han9.jpg
1mPi 9x523 w1.36v
http://i43.tinypic.com/vpavyv.jpg
and finally 8.5x530@4500 w/1.34 ddr1272 w/2.24
all runs use basicly the same settings except vcore and vdimm and vMch/vtt
http://i39.tinypic.com/34ryhsn.jpg
its nice to finally have a cpu that needs so little vcore.
i havent had to use more than 1.36v so far:D
when i get better cooling i'll be able to go 1.39v and see what
it really can do:up:
@radaja
Please, could you put in your bios-settings in this Code when running your CPU with for example 4,5 Ghz? If you didnt set manually please put in auto or standard.
Thx & greatings...
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .................: Auto
CPU Clock Ratio .........................: 9x
Fine CPU Clock Ratio.....................:.0
CPU Frequency ...........................:
Clock Chip Control
CPU Host Clock Control...................: [Enabled]
CPU Host Frequency (Mhz) ................:
PCI Express Frequency (Mhz) .............:
C.I.A. 2.................................: Disabled
Advanced Clock Control:
CPU Clock Drive..........................:
PCI Express Clock Drive..................:
CPU Clock Skew (ps)......................:
MCH Clock Skew (ps)......................:
Performance Enhance......................:
Extreme Memory Profile (X.M.P.)..........: Disabled
(G)MCH Frequency Latch...................:
System Memory Multiplier ................:
Memory Frequency (Mhz) ..................:
DRAM Timing Selectable ..................: [Manual]
CAS Latency Time.........................:
tRCD ....................................:
tRP'.....................................:
tRAS.....................................:
Advanced Timing Control:
tRRD.....................................: Auto
tWTR.....................................: Auto
tWR......................................: Auto
tRFC.....................................: Auto
tRTP.....................................: Auto
Command Rate (CMD) ......................: Auto
Channel A Timings Settings:
Static tRead Value.......................:
tRD Phase0 Adjustment....................: Auto
tRD Phase1 Adjustment....................: Auto
tRD Phase2 Adjustment ...................: Auto
tRD Phase3 Adjustment....................: Auto
Trd2rd(Different Rank)...................: Auto
Twr2wr(Different Rank)...................: Auto
Twr2rd(Different Rank)...................: Auto
Trd2wr(Same/Diff Rank)...................: Auto
Dimm1 Clock Skew Control.................: Auto
Dimm2 Clock Skew Control.................: Auto
DDR2 Write Training......................: Enabled
Channel A Driving Settings:
Driving Strength Profile.................: Auto
Data Driving Pull-Up Level...............: Auto
Cmd Driving Pull-Up Level................: Auto
Ctrl Driving Pull-Up Level...............: Auto
Clk Driving Pull-Up Level................: Auto
Data Driving Pull-Down Level.............: Auto
Cmd Driving Pull-Down Level..............: Auto
Ctrl Driving Pull-Down Level.............: Auto
Clk Driving Pull-Down Level..............: Auto
Channel B Timings Settings:
tRD Phase0 Adjustmen.....................: Auto
Channel B Driving Settings:
Loadline Calibration.....................: Disabled
CPU Vcore................1.250V*.........:
CPU Termination......... 1.200V*.........:
CPU PLL..................1.500V*.........:
CPU Referen..............0.760V*.........:
MCH/ICH
MCH Core.................1.100V..........:
MCH Reference............0.760V..........:
MCH/DRAM Ref.............0.900V..........:
ICH I/O..................1.500V..........:
ICH Core.................1.100V..........:
DRAM
DRAM Voltage.............1.800V..........:
DRAM Termination.........0.900V..........:
Channel A Reference......0.900V..........:
Channel B Reference......0.900V..........:
here you go.9x500@4500 ddr1200 pl8
and to go higher i just changed vtt/mch vcore/vdimm up a notch.
Code:MB Intelligent Tweaker(M.I.T.)
CPU Frequency ...........................:4500
Clock Chip Control
CPU Host Frequency (Mhz) ................:500
PCI Express Frequency (Mhz) .............:100
CPU Clock Drive..........................:800
PCI Express Clock Drive..................:900
CPU Clock Skew (ps)......................:0
MCH Clock Skew (ps)......................: 0
Performance Enhance......................:turbo
(G)MCH Frequency Latch...................:333
System Memory Multiplier ................: 2.40B
Memory Frequency (Mhz) ..................:1200
CAS Latency Time.........................:5
tRCD ....................................: 5
tRP'.....................................: 4-5
tRAS.....................................:12-15
tRFC.....................................: 30
Static tRead Value.......................: 8
DDR2 Write Training......................: Auto
Loadline Calibration.....................: enabled
CPU Vcore................1.250V*.........:1.35
CPU Termination......... 1.200V*.........:1.28
CPU PLL..................1.500V*.........:1.57
CPU Referen..............0.760V*.........:normal
MCH/ICH
MCH Core.................1.100V..........:1.38
MCH Reference............0.760V..........:0.750
MCH/DRAM Ref.............0.900V..........:normal
ICH I/O..................1.500V..........:normal
ICH Core.................1.100V..........: normal
DRAM
DRAM Voltage.............1.800V..........:2.10-2.12
DRAM Termination.........0.900V..........:normal
Channel A Reference......0.900V..........:normal
Channel B Reference......0.900V..........:normal
