Originally Posted by
Telo
I doubt it's your mount bro. My E8500 does 4Ghz at 1.20v [BIOS setting], and 4.25Ghz at 1.30v [BIOS as well]. Seems to me that anything passed 4Ghz requires a boat load of vCore, and if yours is requiring 1.37v for 4.25Ghz, then you gonna have to juice the hell out of it to get it to boot at 5Ghz.
Unless you are just trying to see if you can hit 5ghz with it, I would say forget about it since it is just not worth it, at least not to me. The fact that mine needed .10v for a mere 250Mhz, when it only needed .025v from the VID [Core Temp and Real Temp showed the VID for my CPU at 1.175v] to overclock from 3.16Mhz to 4040Mhz. In my case, I'm extremely happy with the purchase and the performance gain from the OC; I'm getting some nice Super PI timings at this speed with my RAM running at 2000Mhz [without tweaking yet, set to 8-8-8-16-1T 1.95v]. Once I iron out some kinks in my config, it should be rock solid.
