I'm not bashing him? What the :banana::banana::banana::banana:, get a clue. But he said he's leaving the board to go to another because of a problem in a beta bios. At least, that's my understanding of it.Quote:
Originally Posted by feek
From what I've read the only bios that doesnt do this is the F4. I was using a beta bios in the hopes that the board would work correctly.
Well, there's a reason why it's called beta and not final; there will be bugs.
Originally Posted by HeadOn
umm, from what I've read the issue on a cold boot where the DS3 doesnt save the overclock isnt just a bug, it's been an issue with this board from the beginning. I'd call that a nagging flaw - not a 'bug'.
I still have a p5b-e that I had no problems with - other than lack of vdimm (2.1v max) and I wanted to give a DS3 a try and see if it was capable of the same OC. It was an experiment. Overall it did great, in fact I liked it better than the Asus P5B-E, loss vcore droop, more vdimm, mch and FSB voltage adjustments... however something like this, defaulting to stock settings on a cold boot is just downright annoying and Im going to go back to the Asus board for this reason alone. This isnt a new problem with the DS3, it's still not a resolved issue.
Anyways, it has nothing to do with me using a beta BIOS - earlier BIOSes had issues with D9 over 450. I needed 500 - 516 to match the performance of the Asus board so there is no reason to drop to f4 to save my overclock and thus limit the OC to 450 Mhz FSB. Hopefully this clears up what and why I was complaining about it.
Dean
Yea beta, as in the S3, DS3, DS4, and DQ6 boards are Beta products from Gigabyte and we should all expect these kinds of flaws from Beta products :)
My question is: "do we get paid for beta testing their products?"
It's a good thing I got my Wii yesterday. It keeps my mind off this damn board!
I can POST at 500, and I do not think I have memory issues (if so, I don't give a :banana::banana::banana::banana: because this board is screaming @476 and stable).Quote:
Originally Posted by MartianInvader
I'm just hoping to get a few more mHz maybe. Otherwise, like I said above...:stick:
I'm expecting a free 2.0 mobo in the mail :DQuote:
Originally Posted by cold_realms
With F7 for the DQ6 i can hit 438-440FSB...but the new betas are pants for overclocking. **i got my OCZ 850W PSU today - woot!**
While trying to hit the magic 3.6ghz overclock with a e6600, I reached a point in my voltage increase where further increases in the setting yielded some strange readings from cpuz.
When I set the cpu vcore voltage to 1.45V or above, cpuz will report back the vcore as 1.212V and occassionally fluctuating to 1.414V. If I set any voltage below 1.45V, the voltage seems to be bumped up in a linear fashion how I expect it to be bumped up. I tried disabling c1 halt, eist, thermal protection, virtualization, and in windows set it to always on, but I still get the voltage drop as soon as I set it to 1.45V. Does everyone else seem to have that problem?
edit: had the problem with cpuz 1.36 and 1.38 and using F7 bios still
DQ6 2.0 review!
http://www.ocworkbench.com/2006/giga...Q6-REV2/g1.htm
Thats not a review, thats just pictures of the board..Quote:
Originally Posted by Richard Dower
Dammit...don't split hairs :stick:Quote:
Originally Posted by markopoleo
That seems to be a regular problem with CPUZ. It doesn't read voltages past 1.45.Quote:
Originally Posted by Rix2357
hi, i have a strange problem ive never had with any of my previous systems (this is my first intel). When i restart from windows, all of my disks just turn off just a second or two before system actualy restarts and start spinning on again while drives detection screen is up (this doesnt happen with manual press reset button on the case). anyone have any idea whats wrong, ive tested two different PSUs so im suspecting board itself in some way (DQ6 i have tried F6,F7,F8c).
Second question: Is there a way to turn off NCQ in windows, on my old board i could do that in hardware manager, i cant even disable the disk cache as that option is grayed out for me. (also i cant remove safely any hdd as it doesnt appear on the list of usb devices, you should have hot swap option with sata.)
thanks for any ideas.
Originally Posted by olhado
I know it's quite common as I read about this on other forums too but is it normal? Is there anyone else here who has this issue at stock speed?Quote:
Originally Posted by ezechiel1917
I wonder if one shoud leave it as it is and believe that it doesn't harm the system (hdd) and maybe some future BIOS fix it. Or is it reason to RMA the board?
I tried to enter timings manually but it didn't help.Quote:
Originally Posted by corsair8575
Vista is near and I was looking for excuse to try different RAM. So yesterday I moved from 1GB PATRIOT 5300 to 2GB GEIL ULTRA 5300 and still no improvement. I entered timings in BIOS, set voltage as stated on sticks and computer still cycling before post - maybe even more than eariler - now 2, 3 or 4 cycles before post.
There's one more thing I noticed yesterday. I set timings to 3 4 4 8 (DS4@F7E) and when I check them in CPU-Z or Everest it shows they are 3 4 4 9... Maybe BIOS and mobo try to set optimal timings on their own and cycles when doing it...
I can post at 520 with my 120E geil kit.... :slap: and it's sp1m stable to 522 ;)Quote:
Originally Posted by Tac0
The issue is I got a €500 ocz kit, which doesn't even come close. Don't tell me because you think you got no issues because you're running 476 fsb, think ur on x2 ram multi which is below spec for my ram, that the board doesn't still have the same issues.
How did You do that? I've tried flash my DS4 with DQ6 F7 bios, from QFlash, but I've got error checksum or something like this. I can't flash it.Quote:
Originally Posted by DStealth
use @bios =.=" there's only 2 ways to flash your bios unless u got some 3rd party stuff...Quote:
Originally Posted by Jimmy007
QFlash is better than @BIOS ... it's the floppy thing
Originally Posted by ScythedBlade
They make pills for that now.
:p:
Sorry - back on topic.
Update- It appears Gigabyte figured out the disappearing OC settings on some of the boards. I will have more information tomorrow.
Originally Posted by bingo13
Alle- luia :eek:
So much hating the damn thing, with each power ON.
QFlash doesn't let you flash ur DS4 with DQ6 bios... I'm not an @bios fan tho... only used it once to flash my DS4 with DQ6 F7Quote:
Dammit. ..and I'm about ready to RMA this thing too.Quote:
I went back to F8I just to give it the benefit of the doubt. Worked great all night. This morning I had about 10 boots in a row, warm and cold that it wouldnt hold the OC. Finally it started working again. I even decided to give F7 a shot but it couldnt OC over 470 for me. Tomorrow I've got an Asus P5B Deluxe coming its too bad I really liked this motherboard.
