Banned from the ASUS forums. :ROTF:
Thanks for the Tech Points. I never look at them if you wouldn't have told me I would never have known it.
I doubt it!
I just open up a new thread about a new bios version.
Maybe I just canīt reply in the thread "bios 0902".
600fsb would require meni volts on mch - which i would like to avoid.
The overclock profile is going to give us the possibility to run with higher FSB. How high is something that I don't know. If all goes well we should see Quads run with FSB 500MHz stable with reasonable voltage on the NB.
How high you are going to get the FSB with a Dual is also going to depend on what voltage it's going to take on the NB.
To run 600fsb 1:1 I needed 1.61v on mch what is pretty high in my opinion.
The overclock profile is going to be more relaxed so we can aim for the highest FSB so we shouldn't need that much voltage anymore for high FSB.
I expect the voltage to be at 1.55V for FSB 500MHz with a Quad and that's a lot better than 1.70V that I needed with Ai Clock Twister Lighter to be able to run Prime95 or LinX.
A lot depends on what ASUS is going to give us. It's pure speculation of what I've found with testing BIOS 0902.
1.61V is pretty low voltage for x38/x48. 1.65V is optimal for air with active cooling.
At least where seeing progress...as long as the items listed as "may be implemented" are actually implemented :D.
@Fritz_the_germ
I can post on the ASUS forum but not on the Rampage Formula BIos 902 -2 thread as well it's an issue with that particular thread
Thanks leo. I appreciate the info.
Will that matrix driver work under XP also?
:cool:
__________________
Asus X48 Rampage Formula / Intel Q9450 2.66 @ 3.2 / 2 x 2GB OCZ Reaper HPC PC2 8500 /
Asus Radeon HD4870X2 Tri-Fan 2GB graphics card / 24" DeLL Ultrasharp 2408WFP monitor /
Western Digital Raptor X Hard Drive / Two Western Digital Caviar RE2 WD5001ABYS 500GB 7200 RPM SATA 3.0Gb/s Hard Drives /
Creative SoundBlaster X-Fi Elite Pro 7.1 / Creative Gigaworks S750 7.1 Speaker System /
Lian Li 343B cube case / PC Power & Cooling Silencer 750 Crossfire Edition /
IOGEAR GCS1782 GCS1782 Dual-Link DVI KVMP switch with 7.1 audio
@Traveler
Yep they work with every windows (from 2000 - win7) including x64 versions
here's the link
http://downloadcenter.intel.com/Deta...=2101&lang=eng
It should give us the overclock sensation that a P45 can give you and maybe better because our NB can take a lot more voltage.
The reason that they probably don't allow everyone to post in the thread is to keep it on topic and don't have to search for information that is useful for them.
Guys I've received a mail from ASUS RD Team to confirm the issues with the BIOS. :up:
They also have problems trying to get the board running stable with a FSB > 450MHz. They are going to try to fix it. :D
A Happy New Year and it looks like it's going to be great year for us ASUS Rampage Formula users. :yepp:
Thats very good news it looks like 2010 is going to be a good year for this board
edit: from reading the reply in the asus forum it seems that they'll add tREF and the other features we asked for if it is possible so happy new year everyone
Happy new year guys and let the power be with our motherboards when the new bios arrives! :D
I think that after seeing the post with the picture of a DFI Lanparty DK P45 T2RS Plus with a Q9650@4.5GHz, ASUS knew something has to be done.
You've got a DFI Lanparty DK P45 T2RS Plus stable at FSB 500MHz with 1.35V and you've got an ASUS Rampage Formula X48 "trying" to be stable at FSB 500MHz with 1.75V. :D
Farwell great board, Core 2/4 Duo/Quad.. (have to say the Asus Rampage is a stormer :p x48 memory limitations, let alone the dreaded stap (920))
2/3 channel ic5/7
Gigabyte hi-multi stable
v9.a bios ;) *read 7 ;)*
RIP
Any news?
Nothing new. I thought that ASUS would have given us something already to try out and see if things are better but nothing. :(
That could mean that it's difficult to add or fix things or that they didn't take or haven't got the time to do it. :shrug:
I hope that it won't take to long or I can wait an other year to try to get it stable at 4.5GHz because I won't risk damaging my hardware with to high room temperature.
Let's hope for a release date within this month. Winter is perfect time for bench sessions and torture testing.
I'm seriously debating getting a refurbished ep45-ud3p that i can get for 130 AUD but i'm not sure if i'd get much if any improvement, sure i'd probably able to go to 3.6ghz with the increased GTL tuning but i wouldn't be able to get much more.
For those with seriously untapped potential like a q9650 i'm suprised you guys have stuck around this long :D
Reading all these threads about skew and gtl i want to advise some not to play with them if they want only to find a 24/7 setting.
Put 0.63x and 0.67x and skew to auto.
Then the voltages should all be set manually to lowest values
(nb,sb,pll,fsbt etc) and start raising only vcore,vmem and vnb when it is needed.
I managed 32m/3d Marks at 4500@Air with my current setup by only raising vcore,vmem and vnb.
VTT is also very important.
