Because the driver is not digitally signed you need to load the operating system in test mode. Also you may use Driver Signature Enforcement Overrider or ReadyDriverPlus.
The first beta one you posted would give me the error but the second works fine, I guess the beta doesnt like win7.
http://i131.photobucket.com/albums/p.../Untitledv.jpg
Hoss331, fine! I'm glad that was able to help you :)
Sorry guys but I'm told there is no temp sensor inside the actual NB on the UD3P.
Armored_Kech1, sensor inside chip, not in mobo! This sensor has many chips: 945P/PL/G/GC/GZ, 946PL/GZ, P/G/Q965, Q963, G35, P35, P31, G33, G31, Q35, Q33, X38, P45, P43, G45, G43, G41, Q45, Q43, X48. This program reads the value directly from the chip, like CoreTemp reads them from the CPU.
loco23.do you know the name of the driver?
This is a hard question :) 5 sec please..
radaja - "Mama Hardware Access Driver", Path - Windows\system32\DRIVERS\Mama.sys
thanks:D
No problem, just two questions, what cooling are you using? and how much RAM are you using?
Anyway heres what I recommend, but it might change a bit once I know the answer to those two questions.
So pretty much what you do for the References is, set your CPU Termination to 1.2v (stock) then set both the CPU and MCH references to 0.760. Then increase the CPU Reference by to steps (with the + key on the num pad), and lower the MCH Reference the same way.Code:******Gigabyte EP45 UD3P******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ 0 ]
CPU Frequency 4.05GHz...........................[ 400 x 9 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 400 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 800mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance [Standard]
Extreme Memory Profile (XMP)....................[ Auto ]
(G) MCH Frequency Latch.........................[ 400MHz ]
System Memory Multipler.........................[ 2.66D ]
Memory Frequency 1066...........................[ 1066MHz ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD............................................[ Auto ]
tWTR............................................[ Auto ]
tWR.............................................[ Auto ]
tRFC............................................[ Auto ]
tRTP............................................[ Auto ]
Command Rate (cmd)..............................[ 2 ]
******Channel A Timing Settings******
Static tRead Value [ 7 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ 1066MHz ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.25000 ]...................[ 1.500 ] - I only use 1.2vcore - if stable then lower until it becomes unstable
CPU Termination [ 1.20 ]...................[ 1.30 ] - I only use 1.2v - if stable lower until it becomes unstable
CPU PLL [ 1.50 ]...................[ 1.500 ]
CPU Reference [ 0.760 ]...................[ I can't remember the number, but its 2 steps up from default ]
MCH Core [1.1 ]...................[ 1.2 ]
MCH Reference [0.760 ]...................[ I can't remember the number, but its 1 step down from default ]
MCH/DRAM Refernce [0.900 ]...................[ 50% Of the RAM Voltage ]
ICH I/O [1.500 ]...................[ 1.500 ]
ICH Core [1.100 ]...................[ 1.100 ]
DRAM Voltage [1.800 ]...................[ Whatever your RAM needs ]
DRAM Termination [0.900 ]...................[ 50% Of the RAM Voltage ]
Channel A Ref [0.900 ]...................[ 50% Of the RAM Voltage ]
Channel B Ref [0.900 ]...................[ 50% Of the RAM Voltage ]
******Advanced BIOS Features******
CPU Multithreading..............................[ Enabled ]
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
Also if this doesn't work try different BIOSes, they can make a massive difference.
PS. sorry for the late response.
wow this ram is doing pretty good also.i bought this kit about 1 1/2 years ago.for my amd machine.
i didnt think it would OC so well.i thought maybe 950MHz.i was wrong.
http://www.newegg.com/Product/Produc...82E16820231098
http://i41.tinypic.com/2vd0cic.jpg
yep, the 4x2GBs were those Crucial value kits.
my current max CPU-Z validation on my Q9550, also using the 2x2GB Crucial value kit
http://img33.imageshack.us/img33/931...0516195915.png
Originally Posted by Eeky NoX View Post
To Radaja, Panging & OC Nub : If you wanna know what's the DDR3 version really gat in terms of potential,
just have a look sometimes on my french thread, I'm hardly workin' on it for now
http://soj.mesdiscussions.net/soj/in...jet_2430_1.htm
I think 600fsb is possible with dualie's...but the PC16000 is hard to go in the specs and I don't know if it comes because of me, the mobo or the D9s
i think i probably knew about potential of my DDR3 board by myself already, but thanks for the info that you posted at over there anyway.
anyways this's what i've found so far, one of my E8400 fairly easy go to 650FSB, another one was around 620, but they were just for some CPU-Z validations or for 1M SuperPi's.
as for Q9550, myself and friend have played with 2 EP45T-UD3R rev 1.0 and 3x Q9550's... on air-cool and 1.58v (cpu-z) vcore, they were almost maxed out booting from bios at the same 540FSB.
however, i'm not quite sure whether CPU or boards that maxed out on the fsb, and this mostly because i don't have a lot of experiences with the fsb overclocking.
Ok, since about a week ago I have been trying to get 500FSB x 8 or 8.5 with 2.4B with my new Kingston HyperX DDR2-1150 2x1GB kit. I was on F9 at the time and could not get system to boot with 500FSB 2.4B for 1200 RAM. It didn't even like 2.0B as I figured I would boot with 2.0B and then change with ET6 in XP to 2.4B. I then went back to F6 bios and was able to post but would get BSOD's or lockups loading XP. So I went back to square one to see if my RAM could even do 1200...set everything to stock 333FSB x 9.5 (3.16ghz), all voltages on auto (no LLC) except RAM @2.20v, all timings and subs auto except 5-5-5-15-2T. It boots fine with RAM at 1066 (3.20B) and MemSet comes up as PL6 and tRFC 42. So I raised FSB in ET6 to 360 (3.42ghz) to check RAM at its default of 1150mhz, I kept PL at 6, tRFC at 42 and volts at 2.20. Ran HCI Memtest for an hour and prime blend for an hour, no isues. Great I figure I would try 1200mhz, rasied FSB in ET to 375 (3.56ghz), raised vcore to 1.3 and still kept PL at 6, tRFC at 42 and volts at 2.20. Ran HCI again for about 45min to 1 hour and then Prime Blend. Prime was at about 1-1/2 hours and then I went for a walk. Came back and blue screen crash. Hit reset button and then had a continous loop reboots unitl I turned power off. So it crashed anywhere from between 1-1/2 to 2 hours.
Am I right in thinking that RAM is probably good for 1200, but PL needs to be raised along with tRFC and volts? 1.30 vcore should have been plenty for 375FSB x 9.5 right? I'll start with some of you guys 500 2.4B templates tonight hopefully. Thanks.
whats your mch voltage at?
Double.Delete pls.
http://www.xtremesystems.org/forums/...4&postcount=81
http://www.xtremesystems.org/forums/...&postcount=142
http://www.xtremesystems.org/forums/...&postcount=148
http://www.xtremesystems.org/forums/...&postcount=161
http://www.xtremesystems.org/forums/...&postcount=177
http://www.xtremesystems.org/forums/...&postcount=238
http://www.xtremesystems.org/forums/...&postcount=259
http://www.xtremesystems.org/forums/...&postcount=299
http://www.xtremesystems.org/forums/...&postcount=329
http://forums.tweaktown.com/f69/bios...h-guide-27576/
http://www.xtremesystems.org/forums/...&postcount=555
http://www.xtremesystems.org/FORUMS/...&postcount=666
http://www.xtremesystems.org/FORUMS/...&postcount=780
http://www.xtremesystems.org/FORUMS/...&postcount=799
http://www.xtremesystems.org/FORUMS/...&postcount=831
http://www.xtremesystems.org/forums/...&postcount=822
http://www.xtremesystems.org/forums/...&postcount=831
http://www.xtremesystems.org/forums/...&postcount=986
http://www.xtremesystems.org/forums/...&postcount=992
http://www.xtremesystems.org/forums/...postcount=3128
This is about all you need to know about OC on this board.Read these posts.:up:
Also best bios for me was F4 because i got stability with 500fsb at 1.24V Mch.
Nice summary!
I'm considering getting a Q9650 now, I want quad. :(
Well...my UD3P was making stability for 450fsb at 1.4Mch , 1.45VTT and 1.7PLL....and i decided i was way too high after what i have seen through this thread.Quote:
Nice summary!
So i started reading this thread.I'll hopefully continue going through it and find out all the ram OC secrets.
