Wrong...(you have right there if its on ultra-d, sli-D) but on the expert/venus the PWMIC is on the right side on the cpu socket close to the power conection(24 pins)Quote:
I concur with v0dka on my personal experience. Even if you passed memtest for certain memory setting, there still exists room to wiggle around and make the memory more stable in real-world application. I'll give you an example. My Corsair 2x1GB passed memtest for 8 hrs on Expert while that setting could never go for more than a second with any benchmark. SuperPi errored out as soon as it started. Windows had frozen screen. I spent hours only to find out, it's the DRAM Drive Strength issue. On my Ultra-D it's ok at Level 7 so I just copied that value to my Expert. Turned out, it has to be Level 9 to be stable with the Expert.Quote:
Originally Posted by showmanlkz
I'm not saying DRAM Drive Strength is the solution to your problem (keep in mind that every RAM is different.) While I was troubleshooting my Corsair, I also played around with other options such as DRAM Data Drive Strength, Max Async Latency and Read Preamble, etc. Just because one setting passes the memtest, doesn't mean it is the exclusive setting that can pass at that speed. So have fun tweaking some more!
I actually don't know what Merlin BIOS is based upon.. AFAIK, folks at DFI-street are very happy with it. My Expert had trouble with official 406 BIOS (can't push FSB > 300MHz) but once I flashed it to Merlin 10-07-2006, the FSB could finally go as high as my Ultra-D (~355MHz.) TMod's v9.0 CD has a more recent Merlin BIOS release. Give it a try if you have exhausted all the options. Hope this helps.
Ok thanks guys, I knew memtest wasn't 100% but but I never had a situation where it wasn't. I'll check out this merlin BIOS. Does anyone know though why with the 3.3V jumper Mod though I don't have more than 3.2V available? For some reason I think I recall that your not supposed to flash your BIOS with the jumper mod...can anyone confirm?
You need first sett it to 3.2 v to get the higher vdimms... i think also all cpu vcores need to sett to fixed value(not auto)
Damn, that was it, I forgot about the CPU Voltage thing!
Originally Posted by vws
I also found Drive Strength and Data Drive Strength would do the trick sometime even I am not sure what they do. Hardly find info abt them.
If the pc only froze or the superPI, ORTHOS just reported error but keep the pc running, it is fine and I know that prob either ram or cpu problem.
But it wasnt, many of the time it just power off by itself which is scary me.:slapass:
Hopefully it was just casued by the ram, not the damage of the mobo
dual priming @ 3003MHz at the moment .
Opty 175 CCBEE @ 1.4V
273 x 11
will post pics in a few hours if this thing stays stable...
DevilCry, how'd it do? Any further testing? Stable?Quote:
Originally Posted by DevilCry
This is really annoying, My RAM is memtest stable, Dual 32M PI Stable and snm memmory checking stable yet I still get Firefox and Supreme Commander BETA crashes...
You probably got software issues then, or do the problems dissapear on lower speeds? How's prime?Quote:
This may sound like a stupid question but is it necessary to install the AMD processor drivers and the dual-core hotfix? More accurately, does it help stability when running Orthos? I've been running my 175 for over 6 months at ~2.7Ghz but can't seem to crack the 2.8 barrier and I'm wondering if those may have an impact because I haven't installed either.
won't hurt to tryQuote:
Originally Posted by Classic Satch
do you know your stepping by any chance?
It's CCBWE 0550 UPMW. And I have it under a Coolit Freezone. Dual-priming at ~2.7@1.56v gives me Core Temp readings of ~50C. I was under the impression that the AMD processor drivers were only useful if you planned to use Cool n Quiet.Quote:
Originally Posted by stormshadow
yea - i figure that it probably wouldn't hurt anything to try...Quote:
1.56V? I'm a first time opty owner so i don't know but isn't that a bit high?
It's not a problem as long as your temps are OK. 50C is fine for that voltage. I'm actually selling my 175 and grabbing a 165. Of course I'm going to ascertain the stepping first, this time around. Hell, half the fun is just overclocking these suckers. Then I'll worry about my gaming addiction.Quote:
haha - yea. I got lucky on my roll of the dice and picked up a CCBEE. Coming from a 3500 Newcastle :cussing: , I can tell you I'm pretty impressed w/ my 175...Quote:
out of the box it was 2.8 stable on stock voltage...
i'm working on a stable setup right now so that i can be a member of the 3GHz club :D
Good luck brother. :)Quote:
This is at 200Mhz and is 12+ hour dual Prime stableQuote:
Originally Posted by v0dka
I posted a a few pages back saying that I was having random lockups and stability issues on opty165 stock or clocked.
I found out from the Abit forums that my board (Abit AN8) + nforce4 has known problems with onboard USB 2.0 and dual core cpus. I could create lockups at will by just attempting a transfer of a large file ~1gb to my ipod. Changing the bios to USB1.1 cured that lockup.
I've now ordered a NEC pci usb2.0 controller and will disable the onboard one.
Thought it may be of help to somebody.
Cheers H
Definately software related then, start removing drivers one by one until the application that crashes for you stops behaving that way.Quote:
That's very good to know - does this bug only happen during sustained USB transfer? I have an AN8 Ultra and I haven't noticed this problem, I use a couple of USB hard drives for work as well :PQuote:
Originally Posted by hmillhouse
Hello all. im new at this forum but i've read a lot of post by years here. A good site where learn about pc's ^^ :clap:
I've bougth an opteron 180 and this is the step.
Can u help me with it?
OSA180DAA6CD
CCBWE 0543 UPMW
Thanks :rolleyes:
My lock ups would be totally random. I have a few things connected to usb, ipod, printer all in one, Ps2 controllers, hub, mobilephone cable, digital tv receiver etc. I'd be surfing or in Word. More frequently, we'll be playing a game and it would freeze (the ps2 controllers).Quote:
Originally Posted by halo112358
The sustained transfer was the only surefire way to get it to freeze on demand. I think its a bug with early revisions of the motherboard, but doesnt affect Bios 15 (the 1st to support dual core), but does with all 5 subsequent ones.
Hopefully the new USB pci controller will work without conflict.
lol got my Opty 165 0617fpmw some cold this day.. its coldbuged bad, when temp its around +6c-+10c its look with htt over 350mhz :( , i will test the Opty 170 later.. i think it will be much easyer... 10 multi x 350htt =3.5ghz
0615 EMPW @ 3.06 @ 1.525 vCore on Water with my old 2x 512 Kingston Value RAM... I dont know why, but I cannot make it work with my GEIL 2 GB Kit, maybe some of you guys could help me:
http://www.xtremesystems.org/forums/...d.php?t=130490
http://valid.x86-secret.com/ccpuz.php?id=158325
http://valid.x86-secret.com/show_oc?id=158325
And since this is my frist dual core - Why is core 1 around 10 Degree C hotter than core 0 ?!
