Well, I have just recieved my UD3P, the board looks nice, but like always Gigabyte thought that most of users are color-blind.
In comparison to my previous motherboard (ga-x48-ds4) this one have almost twice the options I had before. And that is good from a side and bad (just for now) from other side, because I dont know what does some of those options. And good because I can touch a little bit more.
I attach my Bios options, where I just move slightly some numbers.
And also I bring up (in red fonts) the options wich I dont know what they do, so if someone dont bother, could give me a little explanation.
Thanks in advance.
Template for Gigabyte Users
Code:******Gigabyte EP45 UD3P******
Q9650 389 X 9 3510MHz
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ 0 ]
CPU Frequency 4.35GHz...........................[ 389 x 9 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 389 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 800mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance [Standard]
Extreme Memory Profile (XMP)....................[ Auto ]
(G) MCH Frequency Latch.........................[ 333MHz ] ---> If I have an FSB higher than 400 I should use the 400MHz option here??
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066...........................[ 936 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD............................................[ Auto ]
tWTR............................................[ Auto ]
tWR.............................................[ Auto ]
tRFC............................................[ Auto ]
tRTP............................................[ Auto ]
Command Rate (cmd)..............................[ Auto ]
******Channel A Timing Settings******
Static tRead Value [ 7 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.25000 ]...................[ 1.27500 ]
CPU Termination [ 1.20 ]...................[ 1.260 ] ---> This is VTT? (Which one shouldn be over 1.35/1.40?? And also it refers to Vdrop??
CPU PLL [ 1.50 ]...................[ 1.500 ]
CPU Reference [ 0.766 ]...................[ 0.768 ]
MCH Core [1.1 ]...................[ 1.200 ]
MCH Reference [0.760 ]...................[ 0.778 ]
MCH/DRAM Refernce [0.900 ]...................[ 0.910 ]
ICH I/O [1.500 ]...................[ 1.500 ]
ICH Core [1.100 ]...................[ 1.100 ]
DRAM Voltage [1.800 ]...................[ 2.000 ]
DRAM Termination [0.900 ]...................[ 1.000 ]
Channel A Ref [0.900 ]...................[ 1.000 ]
Channel B Ref [0.900 ]...................[ 1.000 ]
******Advanced BIOS Features******
CPU Multithreading..............................[ Disabled ] ---> I dont know where is this one.
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Enabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
