Originally Posted by cassper1
Hello guys,
I am seeking a bit of advice - I have a DS4 mobo and I've been trying to get proper core voltage readings. This seems to be one hell of a task - differerent utilities seem to report completely different results. I've set Vcore in BIOS to manual, value of 1.275V (I'm running E6400@2.8GHz), EIST, C1E, TM2 all enabled. However, CPUZ says core voltage is 1.248V, no matter whether core clock is 2.1 or 2.8GHz (it reads clocks correctly though). On the other hand, Everest reports Vcore as 1.325V@2.8GHz and 1.163V@2.1GHz. With that said, 1.325 is a 'normal' Vcore for DS4. Any suggestion which other utility to use? Or is there some explanation for Everest reporting 1.325V despite me setting 1.275V? When I used RM clock for Vcore control, Everest used to report exactly what was set in the RM Clock - but I want to avoid using RM clock. Thanks for help.
