Originally Posted by nicepun
Well, I guess I can't really complaint since I do 720/828 @ 1.400/2.101/2.101/1.500 with temps 31c/38c !
Edit1: I just figured out how to OC my card. I leave the GPU voltgae @ 1.400v, but change the VDDC/VDDQ/VDDCI to 2.201/2.160/1.515, respectively to achieve 873, then after it's set, I go back and raise the the gpu to whatever voltage I want for it and raise the core accordingly. I will post results later. I knew card had a little left.
Edit2: Results have been posted on reply #251. I'm not sure if anyone else uses this method to OC their card. Also, I'm using ATi Tool 25b14 only.
