Aren't there 500 BIOS settings in this thread already?
I also had trouble going over 265, and I was able to push to ~272 memtest stable for 20+ loops using the following settings.. you might want to try them! :)
Using these I get ~7100mb/s bandwidth in Sandra
Code:Freq 200 (1:1)
CPC Enable
Tcl 3
Trcd 4
Tras 8
Trp 3
Trc 7
Trfc 13
Trrd 2
Twr 2
Twtr 2
Trtw 3
Tref 3120
Twcl 1
Interleave Enable
DQS Skew Auto
Skew value 0
Drive Strength Auto
DD Strength Auto
Max Latency 7.0 ns
DRAM resp tm Fast
Read Preamble 6.0 ns
IdleCycle Lmt 256 cycles
Dynamic Ctr Enable
R/W Q bypass 16 X
Bypass Max 07 X
G.S Technician Hi,
Welcome to the USA and the Forum. I personally dont own any G.Skill yet, but if your company is making a great effort putting someone like you on the firing line you have my Respect and Interest. You mentioned free photo uploads. Ive tried a few and the best luck Ive had so far is Photobucket. If these Ballistix I have dont work out, then maybe G.Skill will. :) OMG, I just saw the Date on the first Post hahahaha.
Good Luck.
Hi, I've also recently got a set of HZ's and I'm also having problems getting it to pass memtest at anything over 265mhz, been over on kakarotos thread and tried quite a few different vdimm settings but to no avail :(
I had high hopes for this ram as I've seen quite a few people get near to 300mhz, all I want is 270 stable.
these are my past posts to fill you in...
I really appreciate any help :)Quote:
Originally Posted by hesky
Thanks, I tried your settings @1:1 240 would boot 2.5v.Quote:
Originally Posted by LuckMan212
Then tried @245 2.5v/2.7v/2.8v would crash loading into windows.
I'll stick these settings. My memory is gaming stable @265 2.5v 3448 9/10 divider. I was able to run SuperPI 32m @270 3448 which was posted couple of months ago.
http://img69.imageshack.us/img69/7033/dsc028173hd.jpg
http://img206.imageshack.us/img206/1...etting20pq.jpg
superPi 1m @275 2.5v
http://img377.imageshack.us/img377/1...i1m30397mi.png
that's a nice 165 you got there! 2750 at stock volts! :toast:
what stepping?
CCBWE 0550 UPMW 1.4125 vcore is close to stock which is 1.35v.Quote:
http://img293.imageshack.us/img293/1562/cpupic8bi.jpg
I used clockgen to reach 2806 Mhz at 1.4125v. The highest speed it boots into windows is 2700 Mhz 300htt, but 24/7 stable at that speed. http://img381.imageshack.us/img381/2...1m302030rs.png
I only get to 256 Mhz (STABLE) with this memory :(
Can it be the memory controller on my (OLD) CPU (Winchester) ?
it might be somewaht relatedQuote:
Originally Posted by 3r4s3r
What about these settings in BIOS, which do you use?
- DRAM Drive Strength (Level 1-8)
- DRAM Data Drive Strength (Level 1-4)
- DRAM Response Time (Normal, Fast, Fastest)
I was used to pick Drive Strenght @ Level 7 and Data Drive Strength @ Level 2 for Samsung TCCD. But I don't know which is "most recommended" for these G.Skill DDR500 2GBHZ as they are Samsing UCCC.
Response Time I never changed, always set to Normal...
Which Ultra -d bios for a new Opteron 165 and HZ install
704-2Bta is the best
Hi guys
First Post Here :)
Get my pair of these mems a couple of days ago and test a little
Got DDR590@2.76v But not stable
DDR560@2,56 3-4-4-8 Stable
DDR550@2.52 3-4-3-7 Stable
Pic of DDR590 and some of another testes in Everest
I'm a brasilian guy, so, where u see "Escrita"=Write, "Leitura"=Read and ''LatĂȘncia"=Latency :p
http://photobucket.com/albums/y93/gu...illDDR5902.jpg
Some advice to use it whit my opty 144 ang get the most stable performance? Div 10 should be best for me, but 144 multi 9 sucks couse my opty does 2800Mhz vcore default, but 9x280@200Divider (poor performance for my max mhz) versus 9x312@183Divider (Cant get sability on this :confused: ) versus 9x343@166Divider (where i get 280FSB but the opty cant reach it stable.
Anyone whit a opty 144 and this mems to get me a little help??
THX :)
looks very nice to me :)Quote:
Originally Posted by GueD'S
HI, I have 2x 1gb APACER UCCC 2.60v and I dont know if it its working normal at the moment. Can someone tell me the right timeings so that I can make the CPU to work on 3.0GHz http://img301.imageshack.us/my.php?image=ram7lq.jpg
bump
why bump :)Quote:
Originally Posted by Grinch
Originally Posted by G.S Technician
so I could subscribe to post...also wanted to know what you are stting tref value to,to get 100mhz 1.95?
3684 :)Quote:
thx that's what I thought but was not sure...am able to run at 280 1:1...:woot:
hey all,
just got my HZ a week ago now, and am quite happy with the performance.
so far have got it to 265mhz 3-4-4-8 1T @ 2.7v, running 1:1 (memtest stable). this is fine.
but unfortunately, when restarting my PC (or when powering on again after shutting it down), 9 times out of 10 the CPU multi has set itself to x5. this is no fun lol.
i have to enter the bios every time i power my PC on, and set the multi back to 11. even then, the system wont post and i have to reset and do the same again before it will post at the correct speed (weird, huh?!)
i did not have this problem with my old ram, which was 2x512 of Corsair XMS 2700 LL, and has only come since i upgraded to the HZ (some upgrade lol, DDR333 = eugh).
ive been following this thread for a while now and have read it all, and so far it appears noone has run into this problem. has anyone heard of or experienced anything like this before, or can suggest a solution?
cheers guys,
ER
(mainboard is Ultra-D and CPU is 3800 venice if this helps. running 260x11, 1:1, HTT x3).
i LIVE MY STICKS!
I hit 2.9Ghz!!!!!!!!!!!!!!!!!!
cpu multi auto set back to x5?Quote:
Originally Posted by etherealrhythm
yeah :(.
Hi all, this is my first post here.:woot:
I think you have a power problem:explode2:
What power supply you have ?
My friend got the same problem as you, e has a 300W power supply and is PC always started at lower clocks.
I change is PS with an 400w and :banana: :woot:
My HZ are at this moment at 250Mhz 3-4-3-8 2.6v
I start at 3-3-3-8 2.6v, but i got 2 errors on memtest (Test3):p:
I need to check this out, some help to get that chip at 250Mhz 3-3-3-8 please? :stick:
