@ Sebastione
Thanks for info. Going to try it after I reinstall Crysis.
@ Pants on Fire, davetheshrew
Dunno about smart doctor but you can load up MSI AFterburner to check your voltage and overclock settings.
Adjust the config file to allow unsupported GPUs to enable support for the 6900 series. Set it to 1.
You can use HW physX along with ATI using this patch
I am using my 465 GTX in a 4x PCIE slot with unlocked 6950 CF. Using 266.44 drivers with Patch 1.04ff - following the instructions. Super easy. PhysX in Fluidmark, Metro 2033, Mafia II, Cryostasis and Batman AA is working.
Will test Mass Effect and Mirrors Edge later.
Overall FPS is WORST with max / highest physX on but better than cpu PhysX. Check the physX thread in the nvidia forum for my Mafia II quick report.
