memtest test 5 run fine here too.
How about try using 6x multi on DRAM but 18x multi on UNCORE?
Try test it using LINX...
For more testing, maybe try only 2 sticks, different slots, or loosen the RTL
Hi, i have the same problem, OCZ Platinum too.
Thanks but I think I found it. Before I played musical chairs with the memory I set the DRAM switch frequency to increase by 15%. And I left it at that. Now I have every stick running on the channel it fits and I didn't think about the switch frequency setting. As a last resort I remembered and finaly, they like decrease 15%. Result: 20 runs LinX fine. :up: *dances the happy dance*
not copy waza stable yet :( :D
205bootup + PCIE 110
vTT 1.39 + 0.1375/0.01500 set
tRCD/tRP/tRAS/tRFC set in BIOS, others CPUTweaker
LSC on / maxmem 680 / core 1 affinity / no waza
220x21 / x16 uncore / x8 memory / 6-6-6-18
http://i447.photobucket.com/albums/q..._32M_7m49x.gif
220x21 / x18 uncore / x8 memory / 6-6-6-18
http://i447.photobucket.com/albums/q..._32M_7m47x.gif
220x21 / x18 uncore / x8 memory / 6-6-6-18 / tWTR 12
http://i447.photobucket.com/albums/q..._32M_7m46x.gif
220x21 / x18 uncore / x8 memory / 6-6-5-18 / tWTR 12
221x21 / x18 uncore / x8 memory / 6-6-5-18 / tWTR 12
http://i447.photobucket.com/albums/q..._32M_7m44x.gif
32M runs/timing tests (x10 memory)
screenshots + waza runs
http://i447.photobucket.com/albums/q...est-result.gif
Sorry for the late reply. I used to have the same memory as you but I sold it. v2.1 Dominators are elpida ICs. Like you, I had trouble in stabilizing my overclock @ 200mhz and above with my D0. Whats worse is, the more voltage I add, it just made it worse. I had trouble with my C0 as well, but it wasnt as bad as my D0. Im convinced this board has issues with elpida ICs+D0s. Try borrowing another ram set and try again. Prefferably OCZ as I had better luck with my Intel extreme sets.
nice work cheapseats pretty spot on
http://fileshosts.com/intel/DFI/DFI_...6s422ms_tn.png
So this board is good with Xeon? stupid Mwave are a bunch of boners and wont RMA my barely hurt board... so need a new one. Cant decide between this or Rampage II Gene??
No probs with W3520 here with DFI UT X58-T3EH8 @4877Mhz on Water cooling http://i4memory.com/f80/w3520-h20-48...8-t3eh8-18198/ :D
Hmm think I may get this over the Rampage II gene. Unless someone can sway me to the Gene hehe
Okay. Now it gets annoying, I rebooted to save the settings that ran 20 passes of LinX fine, after reboot everythings as unstable as ever. Insta BSOD.
I noticed using CPU Tweaker that my sub timings did not match the XMP for my Dominator 1600CAS8 stuff.... I manually set some stuff like TRFC, did the TRRD set to 14 so it shows up as 6 and some other timings. I also +1 to Channel C on RTL it seems to be doing a little better.
