I have the 8500 set and you should be able to hit 1200+ if your equipment plays right. What I've learned is that you need to have a really good working multiplier/divider. My first crack at this was at high cpu mhz and therefore I could only get stable at about 1175. I've reduced my cpu speed and put myself on the 2:3 divider and I'm stable now at 1190 and counting. When I get home tonight I'll play around with it some more. No reason in the world why I shouldn't be able to get over 1200 since right now my memory voltage is only at 1.84v.
