Are you on water or do you ever plan on it? Foxconn Bloodrage comes with included waterblock for Northbridge! :up:
yeah i'm on water. isn't the NB is not that hot anymore due to cpu memory controller!!
Although they've got one-piece blocks available for the EVGA board, and since the mosfets aren't connected via heatpipe, minimal fuss. Still, the price on those blocks is pretty heady, and makes the EVGA cost a lot more than the Foxconn board.
heard rumor that foxconn channel might layoff, or close? any ideas?
see post 48 http://www.evga.com/forums/tm.asp?m=735106&mpage=2&key=
foxconn isnt going anywhere but up
just fud and econ adjustment
Bloodrage seems to be consistently in stock on NewEgg today, at least when I checked this morning at 10am (when I bought mine), when I checked at midday and just now. Price went up by $10, FYI.
Hope I got one of the newest rev with the resistor fix.
Would Mushkin 1600Mhz CL7 DDR3 work well with this board, or should I go Corsair 1866/CL8? I only plan to OC with a Cooler Master V8 or TRUE, and hold off on liquid. I figure I'll get 3x1GB for now since I plan to run XP SP3 until Windows 7 SP2 comes out. :-)
Check the RAM Compatibility list in the Suggestion Box in the Foxconn section of the forums here.
Guess you mean here:
http://www.xtremesystems.org/forums/...d.php?t=212888
I don't see Mushkin listed.
Anandtech did an X58 motherboard shootout (no Bloodrage) and used this RAM without problem, so that's why I'm thinking it'll be fine in the Bloodrage.
The fact that it worked on another motherboard doesn't ensure compatibility with another board.
The RAM compatibility is going to get "hammered" with plenty additions in the following days, so give it some time and you'll have your answer.
Of course you can give it a try yourself, but nobody can guarantee you that it'll work fine unless somebody tried the model you're looking at and it worked fine.
I have Version 1.0 as I got mine here in Japan as soon as they were available and I have had no problems whatsoever! :up:
My Blood Rage ships out from eWiz Tuesday! I got the Mushkin RAM a while back. Glad to know it works!
Good stuff Dave! :up:
just curious about sli on these board. someone in the evga forum said if the board is not SLI certified even though it says sli support, there is a chance it might now work??
post 64 http://www.evga.com/forums/tm.asp?m=735106&mpage=3&key=
It's sad to see, that there is some people in EVGA forums who is bashing Foxconn all the time. I wonder where is that coming from...
There is some talk about EVGA boards clocking CPU's higher than others in that forum.. No one can tell the truth, cause there must be like 2 CPU's in the world which can go as high as we have seen :rolleyes:
It's all about the CPU at this point.. there is so much variation in Core i7 CPU's, that it must be confusing for masses.
P.S. SLI does work and why isn't this rumor never going to die, even everyone is using SLI without a problem :rofl:
It has to be Fanboy's. I have my 920 on Bloodrage at 4.2Ghz fully stable 24/7 on water with temps of no higher than 62C and I know I could probably get higher. I hate when other manufactures fans talk bad about other brands. :down:
why is this board so freaking hard to get!! everytime i look at newegg or ewiz is out of stock, did they make like 10 each time in china and ship it to here.
No, NewEgg must be getting about 50 boards each time, and every day 24/7 there are hundreds of people clicking F5 on their browser and placing an order as soon as it appears to be back in stock.
