You are incorrect. A thermal probe is not more accurate than the core temp diode inside the processor (source: Intel Corporation, Arctic Silver Corporation, and my own testing.) Even in theory, this concept is completely flawed. How can you obtain an accurate reading of what's inside by measuring from the outside? The internal core diode is the best way to go. Here's a quote from my article, which further details my answer:
The Q6600 was used in our
Best CPU Cooler Performance - Q1 2008 project. There are several reasons NOT to use this processor for testing and comparing thermal pastes, but here are my top three:
1) It doesn't offer a single core reading. Multiple core readings allow for a degree of fluctuation and error.
2) The Q6600 does not get hot enough to create large differences between good/bad TIM products.
3) The stock Intel Thermal Cooling Solution is the best way to get high temps, and it uses a four-corner push-pin mount. This mounting system is very low pressure, and does not compress the elements together with nominal force.
So while you're probably wondering why I would use a socket 478 P4 3.0 OC'ed to 3.6, here are my top three reasons:
1) Single core reading. It is what it is, and there's no confusing the results with an average of four cores. Furthermore, dual and quad core CPU's rarely ever have the same temperature between cores.
2) It gets hot. Add some voltage, and it gets REAL hot.
3) The Intel socket 478 compression-lever thermal cooling solution is probably the best ever made by Intel. The unit does not slide or twist, and it compresses evenly with good force. Additionally, it features a perfect 1" round copper core, which ensures that the same amount of TIM coverage is compared in every test.
