Wait before u come to conclusions... ;)
@Tony...if we (enthusiast community) were to e-mail the companies and ask for more BIOS options, would they listen to us if there were enough voices?
Cheers, and thanks for the effort you`re making :)
Kenny
I'm confused, have just started my intel overclocking,
At 400x8 with one stick of crap ram, I am getting 19second in 1M superpi
At 425x8 I'm getting 18
I thought the strap would lower my performance?
The strap theory isn't so cut/dry. Depending on your setup (BIOS Settings and Hardware) it will change at different places I've found.
it does. at 1066 strap the spi time at 425*8 would be alot better (test it by booting at 1066 strap and then overclocking to 425FSB by clockgen)Quote:
Originally Posted by Vito
the strap lowers and the FSB boosts the speed. at one point the spi time at 1333 strap is quicker than on the " 8*400@1066 " spi time
tell us your rig specs and what memory settings are you using.Quote:
Originally Posted by Psyire
just like a woman
It lowers the RAM performance, but you still have 200MHz more in the 2nd test, so the advantage comes from that.Quote:
No it changes at the same spot every time, its hard coded to do soQuote:
I already asked for you all, so we wait and see. I also know of a new board coming that has 1333 and a ton of bios tweaks...and its not badaxe2 ;)Quote:
Originally Posted by K404
is it equiped with a intel chipset?:eek:Quote:
Originally Posted by Tony
Hi folks,some one got the Multiplier working on 20x (x6800)
if it has 1333 strap it pretty much will be yes.Quote:
Originally Posted by El Snorro
Tony, stop teasing us, at least some hint pls ! :D
More info...http://www.thetechrepository.com/sho...18&postcount=3
I decided to spend a big chunk of this afternoon researching, it seems i965 has some nice advantages over i975 ;)
More soon
T
Great info as allways BT! :clap:
Should have waited a bit longer instead of buying now :(
actually Vito, the P5B Dlx is a very good board.
The rumor is mid december for new boardsQuote:
Tony, are you talking about this? ;)Quote:
ASUS ROG Intel Edition Striker Extreme Mainboard
http://img96.imageshack.us/img96/9170/1yb4.jpg
http://img227.imageshack.us/img227/8098/2uk4.png
just to add more fuel to the fire about 965 over 975, this is a quote from the Intel product overview for the 965 chipset:Quote:
now notice the absence of the bold print for the 975 product overview:Quote:
1066/800/533 MHz System Bus Supports:
Intel® Core™2 Duo processor, Intel® Pentium® D processor, Intel® Pentium® 4 Processor with Hyper-Threading Technology (HT Technology)†, and all other Intel® Pentium processors and Intel® Celeron® processors in the LGA775 socket, with scalability for future processor innovations.
http://www.intel.com/products/chipsets/p965/index.htm
1066-/800-MHz System Bus Supports:
Intel® Core™2 Extreme processor, Intel® Core™2 Duo processor, Intel® Pentium® processor Extreme Edition and Intel® Pentium® D processor to deliver higher performance for games and applications.
http://www.intel.com/products/chipsets/975x/index.htm
Copper tubing sales must be pretty good these days...:DQuote:
Originally Posted by mnemonik23
no I was not, its not an asus based board ;)Quote:
i680 looks pretty slick, chipset runs hot though so we are going to see a lot watercooling it.
I've yet to see a chipset that requires wc'ing. However there is a first time for everything... :p:
just like a woman, hard coded as well
hi all, pardon me for jumping in
Im curious bout this strap thing. Mr. Tony said that 400fsb has an added tweak. I already have bios settings that quite stable (SPI 32M & 3DMark 2005) @470 with P5B-D & E6300, and when i tried to boot @400 and clock it way up to 470 it seems there werent any improvement at all. I mean it gave me the same result as if i booted from 470fsb. But then i tried to boot @399 but it was very2 hard to keep it stable.
Any idea guys?
-tam2-
