I see. You might want to play around with DRAM settings and maybe try a different BIOS. I have had good luck with the latest Merlin BIOS, which can be downloaded with
TMod's BIOS CD v9.0.
PWMIC is the PoWer Management IC that regulates your Vcore and Vdimm. DFI has an excellent execution at this which makes OCing stable and easy. The normal T range on these chips should be around 40-50C.
Magnj: I personally don't like Expert's 406 BIOS. If yours is an Expert I'd recommend Merlin instead. If you use an Ultra-D/SLI-DR then I'd recommend OCZ Tony/BigToe's 406-BTA BIOS which can be had from TMod's BIOS CD link above. I've found that 406-BTA has better tolerance with memory.
