So, anyone knows if my ram is any good? could i achieve at least 220Mhz?
why don´t you just test...?
I cant, dont have the mobo atm and thinking about selling the ram, too...
A pal of mine got these memories:
M2G9JA8ATT9F081AA4
ends with: 1AA4
Now: He's able to do 2-2-2-x at 247MHz at 3.63V
What kind of chips could that be?
winbond chips should end with xxxx1A4TQuote:
Originally Posted by Aleman
is he able to run 2-2-2-5 at any volts at all?
could also be that they are switching codes from time to time...Quote:
Originally Posted by esdee
could be interesting when these sticks are produced -> fully info of sticker needed
i believe its Winbond - either "oldschool" or nex UTT (0,175 - BH)
the 1A is standing fpr 0.175 process and i think noone here is still producing ICs in 0.175 ;)
but like esdee said: why not just testing if 2-2-2-5 are possible with 2,7-2,8V then these should be Winbond based
Originally Posted by Alonso
nice to see you around alex :)
Alonso....remember this:
I'll keep an eye out for you in March...but only if you give me a hint/taste of what's to come
March is almost here. :)
hi guys,
i wanna ask..
my Twinmos SP3200 AA4T UTT 512x2 have error when i test that with Memtest86+
even only in 2-2-2-11 1T 200 Mhz @3v .., that AA4T have 55 error count! what the??!!!
and then when i set back toi standard timing 2.5-3-3-8.. that error still occur
so i think it's not about timing.. but bad memory modules
what should i do ? can i fix it before i choose RMA solution..because when i RMA, i dont think so that i 'll get winbond chipset again..:rolleyes: :rolleyes: :(
Need more info.Quote:
Originally Posted by dhetz
Mobo, voltages,PSU and bios settings.:toast:
ok ..i get it
Mobo DFI Lanparty Ultra B
i put vdimm @ 2.8 (std timing) and 3v (2-2-2-11)
my PSU .. SIlverstone ST405 400 watt
rail 12+ @ 11.95
5 v @ 5.1
(from multi tester)
bios setting standard.. only FSB 200 Mhz with vcore 1.6
thx :toast:
I think I had the best twinmos SP when they used BH5, mine did 1.5-2-2-6 @ 250 1T 1:1, i was happy, then i got some TCCD :D
http://img242.imageshack.us/img242/9030/memstd2.png
is this bh5 or winbond?
bh5 and winbond is the same...
hard to tell from cpuz screen - possible to up a pic of the chips?
TMD7608F8E50D is what chips?are they capable of 2-2-2-5?what oc +-?
skinnie,
http://www.xtremesystems.org/forums/...26&postcount=1.Quote:
DIMMS Found With UTT
(*) Twinmos SpeedPremium (04464 production week,a 4 at the end help too)
(*) Twinmos\Twinmos Twinmos\Mtec chips (cheap ones) (04514 ,same as above)
Make sure if you can take a look at the chips of the RAM that there are
(*) Two Dots marking
(*) Metal Dots (two in each side!)
(*) AA4T [or 1A4T] (not AADT [or ACMT])
(*) week 0xxx4 (the ending 4 is winbond chips)
