Tuniq tower 120, 50ºC loaded on Asus probe and 48ºC on TAT.
Great Forums, I've learned a ton about OC just reading this thread.
Has anyone heard any news about the F8 final BIOS for the DQ6? Is the F8i BIOS improved performance significantly over F7?
Originally Posted by JoeBoXer
Well the F8i allows for OC over 450 Mhz ;)
http://img479.imageshack.us/img479/6...00gbds3nf2.jpg
F8i is for the DS3, the DQ6 has beta F8c...a later beta is due soon.
Quite happy with the ds3 so far. Notice the chipset says C2!!
http://img205.imageshack.us/img205/2...23336amnz0.jpg
Its supposed to come by this week along with the DS4 BIOS but i don't see it happeningQuote:
Well I hope they fixed all the XFi issues or I'll get rid of this board...Quote:
Originally Posted by iceblade
btw. Where is the F7 BIOS for DS4? They are going to skip F7 and release F8???
Thats my guess, since they are releasing F8 final for DQ6 and DS4 is an almost identical board with DQ6. In that case it would make sense to skip F7 in the DS4. As for the X-Fi issues, i have DS4 with F7b and it seems they are fixed, so I hope this would be the case in the final BIOS.Quote:
Originally Posted by xHaste
I had F7B for a short while, but XFi kept reinstalling. Maybe I should try it again, but all links to F7B are dead now, so pity :mad:Quote:
that's a bit strange. I have DS4 and never had problems with X-Fi (Fatal1ty) reinstalling with F7b. Had problem with all previous BIOSes. I have a link though, should you need to try again ;) hereQuote:
be sure to clear DMI when flashing
I have still the same issues. But the worst thing is, that with X-Fi enabled (in device manager) my video playback is a bit weird. Video sometimes skips o bit (a few frames) and i get some "std dev frame time" and "std dev sync offset" in video renderer(shows quality of playback). If I disable X-Fi in Device manager, everything is fine and I have no skips.
This F8 final needs to come out already!
I don't have any floppy disks laying around to install these beta F8s
You can update with @Bios.. is pretty easy and fast.Quote:
Originally Posted by NJDevilsFan21
so how the hell are you going to install the final?Quote:
I bet it's gonna be competitive with P5B Dlx... $179-$189
Can we update the thread title to include the DS3-P?....Ken?
guys can you help me, i installed the f8i and i could overclock to 3.4ghz with my d9 micron memory but when i cold booted it reset my bios settings! is this a common problem?how do i get around thiS?ive email gigabyte and they sent me the f8e bios?would that help me?thanks
Originally Posted by frostman
I have the same problem. Cold boot will randomly reset my OC settings even though they are stable for hours with Orthos. Wake from hibernation(S3) is also broken for some of us. Hope final F8 will fix this.
510Mhz Booted with DQ6 C1 and F8c Bios...
http://xs410.xs.to/xs410/06495/510Mhz.JPG.xs.jpg
is there any point in me trying the f8e? When is the final out?ive read that it was ment to be out weeks ago?
ok guys I get permission from GB to share DS4 F7e BIOS for finding out problems to fix for DS4 F7 Final
if download and test it please share result here or get PM to me
Tanx
Download DS4 F7e Here
At this rate the DS4 F7 will happen at 2007...
haha, I dont know what people were complaining about with the DS3!!
http://img88.imageshack.us/img88/6295/360414125vsz7.jpg
Any links to the DQ6 bios?
Here you have, F8a F8c and F8c :) for DQ6Quote:
Originally Posted by Lee_Kay
http://www.ocxtreme.org/forumenus/showthread.php?t=3348
