well see now this is the deal. i know for sure my 2.5 was and always had been stable at 250x10. thats what i ran with my bh-5 on the 166 divider and then i got the rev2's to hopefully match that at 1:1. ok fine so they did, but with the 2.5-4-4-10 timings. i could not get it stable at all with 2.5-3-3. then sideeffect told me that was horrible and i agreed. but hte problem is, as you clearly understand, that it errors with more voltage. so 2.6v is max volts i can put in it seems. ok fine.Quote:
Originally Posted by sinister1st
then i said, well lemme do a lil test anyways to see if since i CANT use more volts and CANT use tighter timings, what can i do with this ram voltage and timings? what kinda speed right?
bu first, check if its a moot point or not by seeing what the cpu would do anyways. i had never really taken it past the 250x10 anyways on the air.
well i dropped all the multies of course and edged the htt up up up with the 10x multi stock. testing with small ffts to see what kinda ceiling i had. well it got to 270x10 pretty easy (after a while of course) errored at like 273, so i backed it down, tested for a while etc. then said ok, 2.7ghz is good cuz i can use the ol 300x9 multi if i want maybe, use the 270 x 10, etc.... AWESOME.
ok now time to test the ram. so uh, it wouldnt even go past 256 with the 2.6v and 2.5-4-4. so basically i could go nowhere with it. my wall is this hinderance with the volts. i mean its frikken ironic i gave up on using my booster.... gave up on my beautiful bh-5s and got TCCD which shoulda never needed more than the board max of 2.85 to acheive high htt speeds.... yet i cant even use more than 2.6v without gettin what i can only assume is heat errors :(
help me sinister-westcoast-man!
