http://mod-pc.com/modules.php?name=T...=vart&ref=Y558
Thanks, those look pretty nice:rolleyes: high performance..
Totally wrong, it's a Club3D HD3870 Passive Cooling ;)
I have been lurking around the air cooling forums for quite some time.
Here´s my new TRUE:
http://img399.imageshack.us/img399/866/antec03tl3.jpg
http://img137.imageshack.us/img137/7497/antec05rg5.jpg
http://img519.imageshack.us/img519/9089/antec07gh4.jpg
http://img102.imageshack.us/img102/4503/antec08mt0.jpg
The fan is a Scythe S-Flex 120 1200RPM.
Nice looking cat on your avatar, Kolapso :up:
A little sad looking though ... :(
It´s not sad, it´s cute, but more on the point, now that i have the true im thinking of a starting OC of 3.0Ghz, anything that i should think about before i begin? This would shamefully be my first overclock, but you have to start somewhere, right?
Still a work in progress
tj07 fully "air" cooled.
http://img501.imageshack.us/img501/8176/sweetva8.jpg
Before the two front 120mm intakes I had just the two 120mm stock exhausts at the top with the two 92mm fans on the back as intakes. My GPU temp before the front intakes were at 60/58 now with the two intakes my current gpu temps are around 58/50. The temps on my first gtx only improved 1-2 degrees while the 2nd a whole 8-10 degrees. I’m sure my load temps has improved, haven’t done a long gaming session to give you load temps yet!
A huge noticeable increase was my CPU temps. Before the two front intakes I had my TRUE 120 blowing air upwards ( was blowing hot air from the gpus), after rotating my TRUE to blow air towards the back I went from 39-42 degrees idle to a steady 32 on all 4 cores.
Alrite peeps
Below is a pic of my case and coolin etc
Inside Comp Antec 900 = http://www.liquid-network.net/reapa/comp/modded.JPG
GFX Card = http://www.liquid-network.net/reapa/comp/radeon3870.JPG
and im going to be making a fan speed controller for a fan i took off a Rover Engine that was getting scrapped.
Fan = http://www.liquid-network.net/reapa/comp/fan.JPG
reason i need the fan controller is when i have it powered up without one it runs at full rpm and it is very very loud nice jet in me room tbh.
Also got to do some wire management which i may do soon.
Cheers
Chris.
http://i38.photobucket.com/albums/e1...3/Dsc06979.jpg
http://i38.photobucket.com/albums/e1...3/Dsc06980.jpg
http://i38.photobucket.com/albums/e1...3/Dsc06991.jpg
http://i38.photobucket.com/albums/e1...3/Dsc06992.jpg
http://i38.photobucket.com/albums/e1...3/Dsc06997.jpg
http://i38.photobucket.com/albums/e1...3/Dsc06999.jpg
http://i38.photobucket.com/albums/e1...3/Dsc07001.jpg
http://i38.photobucket.com/albums/e1...3/Dsc07013.jpg
http://i38.photobucket.com/albums/e1...3/Dsc07021.jpg
http://i38.photobucket.com/albums/e1...3/Dsc07022.jpg
http://i38.photobucket.com/albums/e1...3/Dsc07023.jpg
Good choic of Mobo there :D
Do want.....so hard.
im definitely putting an HR-03GT and HR-11 on my next video card(probably going to be a G92 8800GTS)
Love that case nathan, such a well known water cooled case, but is very good for air cooling to :)
Updated pics of my rig since adding lots of new hardware.
