Originally Posted by
kpablo
(1)In my case, yes, i have set everything in manual, some of them at their stock voltage, like the IOH, and PCI Express.
(2)About the profiles, you even can't load them anyways... when you try it say something about not matching.
(3)I checked my voltages with a voltimeter and look like it show a little lower compared with what was showing with Bios 1504, so yeah, i tried upping voltages on the critical ones, Vcore Voltage, QPI/DRAM Voltage, CPU PLL Voltage and RAM Voltage, and no go, still i get error at 3 minutes of running LinX. I rolled back to Bios 1504 and passed it.
Anyways you set in BIOs 1.55v you get like 1.48v in full load, at least with my board, measured with a voltimeter.
I had to set 1.525v in QPI/DRAM Voltage to actually give me 1.45v in full load. In idle i get 1.48v.
