:shocked: Nice run there Jor3lBR, and congrats.
Very nice runs! Jor :up:, question though did you down clock it for the spi ss because you have it listed as a 5ghz run on the bot?
Thanks for the kind words guys :up:
Hoss at those speeds and tight timings you have to downclock the cpu otherwise it will freeze on the SS. I would say that they were around 553 - 556 fsb.
My CPU container for LN2 will be ready soon. Wait, Jor :cool:
My and my friend too: no matter -40 or +40 :)Quote:
Originally Posted by Jor3lBR
But low temp important in long test like SuperPi 32M or wPrime 1024M.
Did you have something extra running in the background when testing that time? On mine there is less than 1GF difference between running it at 1:1 916 vs. 5:6 1099, both do around 57Gflops.
As you might be able to guess, I finally got my UD3P - great board so far!
http://i194.photobucket.com/albums/z...10secs1MPI.jpg
Weeeee!!!
'tis indeed, and so chuffed I finally smashed my old 10.062 pi record (and with a quad!):D. I'm now half way through a loop of prime blend at 4.5GHz. Easytune makes life so much easier once you figure out how the refs actually work. Plus there's the fact that it behaves consistently - such an important factor. I plan to solve the lack of sensors & fan headers by getting me one of these. Then I'll gut out the case and route everything nice & tidy, and will actually be able to keep a near silent, closely monitored system again. Right now my rads are down by 2, but everything seems to be holding up ok. Will be back with more speed soon! :D
wow in-fluence great job with your Q9650.at least the MaxII wasnt a total waste,it really helps fine tuning
the OCing skills.kind of like learning on an acoustic guitar and then playing an electric for the first time.:up:
Thanks dude :)
I couldn't have put it better myself with regards to the MaxII. It was a nice, pretty board with bundles of great features, but I doubt I'll waste any more time on it and will probably sell it while it's still worth something.
Just sold my lapped Q6600 too and given it a nice polish. Used it for 2 years and pretty much sold it for the same price i bought it. Was tempted to give it another try in my new board, but I can't make the guy wait.... can I? :ROTF:
I'm now spoilt for choice with what to try for next though... highest stable o/c? or highest fsb? or maybe get my old reapers in there and go for some pi benching?
yep your going to have a lot of fun this holiday season
so many possibilities:D
I made a small improvement in results, but I think
that my MBO has came close to maximum FSB
or, I am just a n00b and I do not know how ... :confused::confused: for now :shrug:
PiFast - 20,58 s
http://www.imagesforme.com/thumb/thumb_e8c401e5.jpg
SuperPi 32M - 10 min 57,829 s
http://www.imagesforme.com/thumb/thumb_ce4670e9.jpg
Super Pi - 9,891 s
http://www.imagesforme.com/thumb/thumb_ab5a8d43.jpg
wPrime - 8,172 s
http://www.imagesforme.com/thumb/thumb_c1f5ef8f.jpg
maybe is time for UD3P
http://valid.canardpc.com/cache/screenshot/886697.png
Finally got 550 FSB, but had to stop going further due to water pump stopping and PC repeadtedly shutting off :eek:!
I'm assuming it's the dodgy 12v atx connector I thought I'd fixed :mad:
Got to the login screen for 557, but then I started getting the shutdowns...
I'm giving the board a rest tonight after that little blast which turned out quite risky, so I'm gonna tighten up 500x9 which I've now got stable. :D
PS, can you run lower than PL9 on 1:1 at 500FSB UD3P? Any recommendations for the drive strength at this speed too?
If your ram can do cas4 you should be able to drop down to PL8 on 2.00D.
yep what hoss331 said.400 strap 2.00D pl8 cas4 was good up 520fsb for me if i remember correctly.
Hmm, looks like I'll be on the hunt for better sticks again. Mine wouldnt go a notch over 1162 unless I loosened some of the sub-timings on the MIIF, might be different here, but I know that board wasn't so bad for memory. Might be able to lower cas to 4 though - will this board simply not post unless cas 4 is set?
Anyway, the most I could push ot of it was 560FSB
I go a bit carried away with the volts and decided not to push further. Jor3lbr, What kind of MCH volts did you use? I was hovering around 1.74....
http://valid.canardpc.com/show_oc.php?id=887013
http://valid.canardpc.com/cache/screenshot/887013.png
Like I said, I'd be biting at your heels, but that 6MHz is a long way away though, and as for max speed, I couldn't get past login at 450x9 - will get back to that another day :D
Well, after another evening of tweaking, I managed to get 4953MHz. Just 2 off 10th place in the hwbot rankings (which I've just discovered and am pleased to see a few of you lot are on). I also nudged down my 1M PI time a little:
http://valid.canardpc.com/cache/screenshot/890154.png
http://i194.photobucket.com/albums/z...nShot002-1.jpg
Pretty proud of myself as this is my first proper kind of opportunity to OC without much limiting me (except lack of a chiller / liquid nitrogen), but I've gotta say that if you intend to overclock these CPUs, then the UD3 range is king. Sorry to nudge you down andressergio, but it does take a lot of tweaking to get into this territory, so kudos to you, and Huuuuge kudos to Jor3lbr!
Once not long ago (actually just before i got my i7) i had a q9650 it was an excelent chip it got me to 4.6ghz on water
