:eek:
Do you have a link? That would be awesome!
http://www.tomshardware.com/news/Nvi...-X58,7012.html
Last line of the main Paragraph.
529th,here you go.
http://www.xtremesystems.org/forums/...postcount=2718
Hello @All:p:
CPU Clock Skew 500ps.
NB Clock Skew 600ps.
Custom W/C @ CPU/VGA/NB
~40min Dual Prime Blend..:up:
Still Testing..:D:D:D
http://img8.imageshack.us/img8/3666/85533th5.th.jpg
And ?
You think a users input here has more clout than a quote elsewhere ?
I ain't saying its happening but I will not be going by above users input anyhow.
If they can do Software SLI on other Chipsets I see no reason they cannot do it on P45.
can and will are two very different things.....
You put your faith in Toms, I'll look elsewhere
Something to get us back on topic Gents.....First try at 4.3Ghz :
http://i16.photobucket.com/albums/b3...504_3ghz-1.jpg
"ugh oh"
Hello guys i've got an answer from the Asus french tech dept and i think i've found someone kind to deal with, my request was about pull-ins, vnb-vtt bug and some of the points listed in the thread of E.V.O, now that person is asking me to type my request in french and explain some stuff so briefly what do u wanna have in the "upcoming BIOS"?
I also have spoken to Asus Taiwan, and the person I spoke with had no idea what pull-ins even were, so you are making good progress.
Ok, what we need is:
- Working phase pull-ins
- Correct vNB/Vtt problem (if possible this may be a hardware level problem)
- tREF setting - for better control over memory
- DRAM Clock & Data drive strength settings - for better control over memory
- CPU, NB and DRAM clock skew in 25ps increments (50ps if 25ps is too fine/difficult for them, but 100ps is way too coarse)
That's just to start with I could suggest a lot more options but I doubt they'd include them.
cryptik,always start high(more things to fix)that way after they haggle it down,you get a little more than you were expecting.hopefully.so lets get everything(all problems)in there.
Thank you CryptiK, I will try to do my best to convince that person, hope this works in the end, and if they don't care, i'm free to harass them with my requests till i become either the greatest shareholder of ASUS or the worst spammer :D
@ radaja - Yeah I agree with that, just trying to find the line between them saying "ok well do a few of those" and "they're crazy they don't need all that we wont do anything". I'm also expecting other guys to make some suggestions so I don't want to take up the whole list with only my suggestions.
I'll see what ideas other people suggest and go from there.
@dawdaw - thanks for doing this any contact with them is a positive step forward. Give it a day or so and check back to give other guys a chance to make suggestions.
Before you send the list to your contact, please PM me the list you have at that time and I may add some more to it.
So I've managed to reach 480fsb with some minor stability testing like Small & Large FFT's each 20 min and here are my settings:
400 FSB strap
1.36875 vcore
1.60600 PLL
1.36500 FSB termination
1.51075 NB
the rest like GTL etc have not been fooled with. testing IBT now, will post results (only 5 passes)
Q9650
MIIF 1901
EDIT: Failed OCCT 46 min into it
