That was link for 1.2.0.b06 with slider.
Yah verified - Coretemp does not work in Vista x64. You'd think after all this time the author would have fixed it...
The issue is driver signing - I don't know why the author just doesn't get the driver signed. Sheesh.
Anyway, SpeedFan seems to be very reliable and accurate. Right now my 3060 is idling at 27C @ 2.4GHz (native) with an ambient temperature of 72.5F.
Whats the Difference??
DRAM Freq.
and
FSB Strap to North Bridge
"The FSB Strap to North Bridge option allows you access to memory ratios tied to specific FSB settings,"
Also whats does PCIE Frequency do for performance and stability?
Still nobody answer my question. :( What's the most stable BIOS version by far and why there is a big jump in CPU temp when I moved from 602 to 802 or 901?
The Jump reflects that the bios was changed to give a more accurate temp figure at the core of the cpu, changed in bios 701. I use 602 but all are not too bad, get lesser scores everest memory with later bios's so have stuck with 602. There someone has answered your post happy lol.:)
Thank you, I appreciate that. :D I actually downgraded from 802 to 602 and the temp went back to normal. ) According to ur sig, you have urs running at 3.6 with 602 and that's what I'm aiming for right now. What yours idle and full load temp like? Do you think it's a good idea to stick with 602 and what BIOS version gives you more accurate temp?
Well,I installed the CoreTemp "fix" for Vista, and it gave me the same #'s as Speedfan.
So my idle @ 2.4GHz on my 3060 is 28-30C. The idle @ 3.6GHz was 54-56C. What's happening here? Why is my idle temp for the 3.6GHz so high? It was ~42C with my 680i. If I were to run my 3060 at the 54-56C idle I'd be hitting 70C+ under load, which AFAIK is a very bad thing.
Here's my voltage settings:
CPU 1.5
FSB 1.5
PLL 1.6
NB 1.49
SB 1.10
Any ideas?
Loadline Enabled
Wow. This makes NO sense. I just lowered my CPU voltage to 1.48, and the PLL to 1.5, and it didn't change the temp at all...
I'm running BIOS 901. Is it possible the BIOS temps are off by 10-15C?
When u set xxx volts for the RAM, u will read like 0.1 higher @ Asus probe and Asus Suit even higher, but did any1 of u did some DIMMreadings? If so by how much does it actually overvolts according to what is set @ bios?
Finally had time to put my WC on... and I'm pissed: board is bending but it's still overheating (~90C) in idle if I give it ~1.5V... obviously the Storm somehow doesn't work.... what should be the normal idle temperature at stock speed?
I got some ridiculous, 50+ Celsius with water... :(
I think you'll find they won't fit mate. They are the Type 1 versions and the same as the ones I had. Its definately the Type 2 versions you need but as I have already said I can't get them in the UK. I have since refitted the original Asus mosfet cooler and its running cooler than it was before anyway! I can only assume this is because the rest of the board is better cooled and the mosfets aren't linked up to the NB via the heatpipe...
This is my settings for 3.4GHz OCCT,Everest and Prime95 stable, maybe it will give you some insight
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8
FSB Frequency : 425
FSB Strap to North Bridge : AUTO
PCI-E Frequency: 110
DRAM Frequency: DDR2-1133
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
Ai Clock Twister : Strong
Transaction Booster : AUTO
CPU Voltage : 1.45
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.61
DRAM Voltage : 1.98
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.050
CPU GTL Reference : Auto
North Bridge GTL Reference : Auto
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Disabled
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Enabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
Just updated BIOS from 701 to 901 hoping it will help if it's a temp reading error but no luck - it seems there's no workaround, CPU got too much compound, I have to remove the Storm and clean it... should've checked it before I have mounted... :brick: :brick: :brick:
i have an issue i need help with
i have this mobo with the shipping bios...401
silverstone 1000w psu, evga 8800gtx, 2x 2 gb g.skill, q6600 go, all this, and i am overclocked 400 x 9 .... 3.6
and i am getting 3200 on 3dmark 06....wtf????
this was both oc'ed and at stock settings....all the newest drivers....i dont understand it....
cod4 plays like crap, with alot of lag....what gives?
my monitor is a dell 3007
any ideas why my score is so low?
the rig in my sig blows this score away....12,000 or something up there
please help me figure this out, i am stumped!!~!
TIA
